1. Re: Player Control Buttons Partially Displayed
Lilybiri Feb 14, 2017 10:34 AM (in response to michellew52859110)Did you create those buttons? Which type of buttons: image buttons, shape buttons? Can you check the InBuilt states of the buttons?
You should be using 9.0.2.437, look in Help, About Captivate.
2. Re: Player Control Buttons Partially Displayed
michellew52859110 Feb 14, 2017 10:45 AM (in response to Lilybiri)No, I didn't create the buttons. All I did was click on the "Preview" button in the toolbar. It doesn't matter which "Preview" option I select (example, "Play Slide", "Project", "From this slide", etc.), the result is still the same. Only the outline of the player control bar displays. And yes, I am using version 9.0.2.437.
3. Re: Player Control Buttons Partially Displayed
Lilybiri Feb 14, 2017 10:56 AM (in response to michellew52859110)Play slide is not a preview method.
Which theme do you use? Is it the default playbar of that theme?
4. Re: Player Control Buttons Partially Displayed
michellew52859110 Feb 14, 2017 11:24 AM (in response to Lilybiri)I went to File > New Project > Blank Project. Then I went to the Master Slide view > Properties and change the slide color to white. The background of my slides needs to be white. Being that I've done the same thing in Articulate SL, I would've never thought that changing the slide background color would interfere with the display of the player buttons. Can you suggest what I can do to display the player buttons, knowing that the slide color must remain white? Thank you.
5. Re: Player Control Buttons Partially Displayed
Lilybiri Feb 14, 2017 11:36 AM (in response to michellew52859110)I wrote an article about Themes, lot of users do not know what is in the theme:
Exploring THEMES (and templates) in Captivate | eLearning
I suspect that the theme (still don't know which one you used) has a playbar with white letters on transparent buttons. You will have to go into the Skin editor (Project menu) and check out the setup of the playbar. Maybe switch to another playbar.
Another approach could be to replace the white swatch in the Theme Colors palette by another color, but that could change a lot of colors in the object styles, master slides as well. SL is another tool, Captivate's design relies a lot on the theme used.
6. Re: Player Control Buttons Partially Displayed
michellew52859110 Feb 14, 2017 11:49 AM (in response to Lilybiri)I went into the Skin Editor. White was selected for the color of the button face, so I selected another color, and now the buttons show - thanks! As for which theme I have, I clicked on the "Themes" button in the toolbar. The options that I have for themes are "Poise", "Simple", "Smart", "Suave", "Vibrant". My selected theme is "White". Thanks for sharing your article and themes and thanks again for your help.
