3 Replies Latest reply on Nov 4, 2017 9:56 PM by angelq
    Adobe DC Form Signing
    Hess1113
      Hello I am trying to do digital signatures for my Eagle Scout Work Book. When I try to sign it using fill and sign "You have opened a fill able PDF form. This form does not let you drag and drop saved information.". I also attempted to sign the form using certificates tool but in the bar to select what to do all of the options are grayed out. I checked the properties of the document and it is sign-able. You can find the document I am using here Eagle Scout Service Project Workbook Procedures the file is called "Eagle Scout Service Project Workbook NO. 512-927". Thank you for your time and anything helps.
           -Christopher Hess
        • 1. Re: Adobe DC Form Signing
          Josh_Corey Adobe Employee
          Hi;
          The PDF is an XFA form created in LiveCycle and would not be supported by Fill & Sign.
          Digital Signatures as far as I can tell *should* work but I also see the options grayed out when I open the PDF in Acrobat Pro DC (I do not know why).
          I moved the thread into the LiveCycle Digital Signatures forum (hopefully that is the right forum) and someone here should be able to help.
          Josh
          • 2. Re: Adobe DC Form Signing
            Since the LiveCycle form did not have "digital signature fields" added when it was designed the existing signature placeholders (they are not form fields) will not be able to be signed regardless of the document security setting for "signing" since the "Modify" is not allowed.
            Since you are a consumer of this form and not the author I won't try to go into what should happen to make the form more usable - you should probably fill out the form in Acrobat or Reader, print and then sign with ink on paper.  Once signed you could mail or scan the form to email.
            Josh
            • 3. Re: Adobe DC Form Signing
              angelq
              Thanks Josh!
              So far, this has been the most accurate and truthful answer in all the forums reviewed.
