3 Replies Latest reply on Jul 21, 2017 7:35 AM by igori15135147
    InDesign CC 2017 crashing on startup
    b2oleary
      Getting the following when opening up InDesign CC 2017:
      Problem signature:
        Problem Event Name: APPCRASH
        Application Name: InDesign.exe
        Application Version: 12.0.0.81
        Application Timestamp: 57f545c7
        Fault Module Name: HYPERLINKS PANEL.APLN
        Fault Module Version: 12.0.0.81
        Fault Module Timestamp: 57f54f9a
        Exception Code: c0000005
        Exception Offset: 000000000000f029
        OS Version: 6.1.7601.2.1.0.256.4
        Locale ID: 1033
        Additional Information 1: 2b99
        Additional Information 2: 2b996f7605e15115a26c4b50879e8d56
        Additional Information 3: a7e0
        Additional Information 4: a7e02ecc09ecbcd5775340ffc890b233
      I've tried uninstalling/reinstalling multiple times, using the Creative Cloud cleanup utility, and deleting the Adobe folders from the C:\ drive and registry.  Still stuck at the same point.
      Thanks in advance!
        • 1. Re: InDesign CC 2017 crashing on startup
          sanyamt Adobe Employee
          Can you please provide following information:
          • Is it document specific? Send me the document?
          • Screen recording to demonstrate the issue after clearing cache and preference
          • Crash dump
          You can create the crash dump for windows using the following method:
          1) Start Task Manager. To do this, use one of the following methods:
          • Right-click an empty area of the task bar, and then click Start Task Manager.
          • Press CTRL+SHIFT+ESC.
          2) Click the Processes tab.
          3) Right-click the name of the process(InDesign, in this case) that you want, and then click Create Dump File.
          Note: If you are prompted for an administrator password or confirmation, type your password or click Continue.
          A dump file for the process is created in the following folder:
          Drive: \Users\Username\AppData\Local\Temp
          4) When you receive a message that states that the dump file was successfully created, click OK.
          Please follow the step to clear preference and cache
          • InDesign Preference:
          Windows XP: C:\Documents and Settings\<USER>\Application Data\Adobe\InDesign\<Version #>\<language>\  (Note: Prior to version 6 [CS4] the language folder is not used).
          Windows Vista or Windows 7: C:\Users\<USER>\AppData\Roaming\Adobe\InDesign\<Version #>\<Language>\ (Note: Prior to version 6 [CS4] the language folder is not used).
          Macintosh: Hard Drive/Users/<USER>/Library/Preferences/Adobe InDesign/<Version #>/<Language>
          • InDesign Cache:
          Windows XP: C:\Documents and Settings\<USER>\Local Settings\Application Data\Adobe\InDesign\<Version #>\<Language>\Caches\ (Note: Prior to version 6 [CS4] the language folder is not used).
          Windows Vista or Windows 7: C:\Users\<USER>\AppData\Local\Adobe\InDesign\<Version #>\<Language>\Caches\  (Note: Prior to version 6 [CS4] the language folder is not used).
          Macintosh: Hard Drive/Users/<USER>/Library/Caches/Adobe InDesign/<Version #>/<Language>/ (Note: Prior to version 6 [CS4] the language folder is not used).
          • 2. Re: InDesign CC 2017 crashing on startup
            b2oleary Level 1
            Hi Sanyamt,
            Thanks for the reply.  It is not document specific, as I am just trying to launch the program, not opening any documents.
            I'll try clearing cache, doing a screen recording, and grabbing the crash dump for you shortly.
            Brian
            • 3. Re: InDesign CC 2017 crashing on startup
              igori15135147
              Hi!
              Can you please tell me was the problem solved?
              I have the same issue here. Clearing the cache hasn't worked for me...
