4 Replies Latest reply on Feb 16, 2017 6:16 AM by Wiedenmaier
    FDK 2017 linker error
      I have installed the 2017 FDK to compile a previous project. I think I have set all the options correctly but when trying to build I get some errors related to the linker. This is the first one:
      error LNK2038: mismatch detected for '_MSC_VER': value '1600' doesn't match value '1800' in fdk.lib(fde_netlib.obj)
      From what I have investigated it appears that the fdk.lib was compiled with VS2012, in the FDK requirements it says to use VS2010 like I have done with previous releases, but in this case I think the FDK libs should be compiled with 2010 also. Please let me know if this is the case or if I can try something else.
        • 1. Re: FDK 2017 linker error
          Russ Ward Level 4
          Hi carlosn41051594,
          I don't have a solution for you, but I wanted to let you know that I did a quick test and I got the same results. I am using VS2010 Express. It is very possible that the documentation is wrong about the VS version, as it contains other fiction related to project settings that have been obsolete for a decade. Please keep us informed if you make any progress on this.
          • 2. Re: FDK 2017 linker error
            Wiedenmaier Level 3
            Hi Russ,
            Hi carlosn41051594,
            I'm not that fast than, so I haven't had a chance to compile against FDK2017 and I didn't run into this linker error, yet.
            My Information is, that FDK2017 is built with Visual Studio 2013.
            _MSC_VER 1600 = VS2010
            _MSC_VER 1700 = VS2012
            _MSC_VER 1800 = VS2013
            So this confirms my Information. So I think documentation is wrong.
            I'm sure there will be ways to work around this, or to reference MSC binaries from Studio 2013 in Studio 2010, but the easiest way is, to upgrade your Studio Version.
            Hope this helps.
            • 3. Re: FDK 2017 linker error
              carlosn41051594 Level 1
              Thanks Wiedenmaier, you are right, 1800 is for VS2013. I have installed express edition in another machine and it builds fine, so basically to use the 2017 FDK you need VS2013. From what I read you cannot use binaries from other release or at least in most cases is not convenient. Wonder if 2013 is really needed or Adobe could compile the FDK with 2010, in my case I can upgrade to 2013 but not sure if it is the case for everyone.
              • 4. Re: FDK 2017 linker error
                Wiedenmaier Level 3
                everyone should. VS2010 is 7 years old...
