3 Replies Latest reply on Feb 15, 2017 4:21 PM by Dave__M
    Change Text Direction
    adivp82400638 Level 1
      Hello, I want to create a document in Acrobat Pro DC.
      In Word, I can to change the text direction by the http://boards.straightdope.com/sdmb/showthread.php?t=504767button, but in Acrobat I can't.
      I also tried Ctrl + Left Shift or Ctrl + Right Shift to change the text drection but it didn't again.
      Example: when writing ?מה נשמע (Whats up?) it shows מה נשמע? (?Whats up). The question mark is above the word but not below it.
      How can I fix that???
        • 1. Re: Change Text Direction
          The link was created by mistake.
          • 2. Re: Change Text Direction
            Dave__M Adobe Community Professional
            Creating a document in in Acrobat generally is not a good plan.  If you create your doc in Word, or any other application that is designed to create and edit document/media, you can convert to PDF once the design is in place.  Acrobat is not generally thought of as an authoring tool, and with good reason - it was never designed to, and doesn't do it well.  Edits to a PDF should be a last resort in cases where the original source document is not available.
            My best,
            Dave
            • 3. Re: Change Text Direction
              Another thought - You may have some success in this by defining the document's default language as Hebrew, if it is not already set as so.  You do this in the Advanced tab of the Document Properties dialog box (ctrl-D or cmd-D on Mac).
              My best,
              Dave
