• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
What is the best way to toggle between different languages using the same help file?
Community Beginner ,
Feb 15, 2017 Feb 15, 2017
Hi all,
I am currently working with my software architect to find the best way to toggle between different languages in the same help site using Responsive HTML. He did some research and found this Generating help in multiple locales using Adobe RoboHelp 10 | ADOBE GLOBALIZATION BLOG
I proposed using Conditional Tags in my Help content, and filter between En, De and ES. I assigned the different languages at topic level within each book (Book 1 contains EN, Book 2 German etc) for each different languages, i.e. Book/Topic - DE, Book, Topic - En etc. And then create Conditional Tags based on the languages. I outputted this and seems OK, but the filters are kind of ugly and I just wanted to know if there is a more effective way using Responsive HTML?
Thanks and kind regards,
Luke Pivac
Views
600
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Feb 16, 2017 Feb 16, 2017
So you have 2 separate outputs as described in the blog post?
Honestly, I wouldn't handle translation that way. I would add every language to it's own project and generate from there. Then add a button to the skin to switch between the outputs. It makes managing content easier and you don't have to juggle with the different languages in the project. When you send files for translation, you can simply send the entire project to the translator and let them send you a translated file back.
Votes
Translate
Translate
Participant ,
Hi Luke,
in my output, I'm not using the same file, but two files with the same name in the respective language folder. The language parameter is provided by my software, so I'm still able to create a context-sensitive help leading to the same piece of information in every language. Maybe this would be sufficient for you, too.
What I have done is this:
In my project, I have a top level folder for every language (EN and DE).
Within these folders, I have identically named subfolders containing identically named topic-files. Each of the files is provided with a conditional tag describing its language.
I create a TOC for each language, containing only the folders and files from the respective language folder.
I create an HTML5 output for each language with the respective TOC, leading to the same directory.
In my SSL, this looks as follows: there is a folder for EN and for DE. In the folder EN (the same is true for DE, of course), there is the index.htm and the other RH-files, and there are my two language folders EN and DE. If you are using subfolders, all of those are also displayed in the DE folder, but they do not contain any html-files. The html-files are only output to the subfolders in EN. Vice versa this looks for the German output.
So you will have to set the language parameter twice, but if you don't use this structure, you'll find both languages in the search results.
Kind regards
Karin
Votes
Translate
Translate
Report
Report
LEGEND ,
Votes
Translate
Translate
Report
Report
Participant ,
hmmm, when I started working with RH, having both languages in one project seemed the most logical thing to me. As I'm doing the translations myself, this is not a problem here. Another benefit of my way is that I can use the same image for both languages and in case of an update only have to update the image once. Also, I design the structure of my topic once and then it's just copy, move, translate. Sure, there are other ways like Resource Manager, but with my number of files, to me having all files for one topic in one project still seems nice. However, I'll think about your proposal a while, maybe it'll in fact turn out to be the better solution even for me. Thanks Willam
Votes
Translate
Translate
Report
Report
Thanks Karin, I look forward to it.
Votes
Translate
Translate
Report
Report
H William,
Thanks, this sounds simple and effective. I like it.
I just output to the responsive HTML output. Can you please tell me how do you "add a button to the skin to switch between outputs?
This sounds like a nice trick that I would like to implement.
Cheers,
Luke
Votes
Translate
Translate
Report
Report
LEGEND ,
Feb 18, 2017 Feb 18, 2017
To add a button, you have to add some code to the Topic.slp. For the Azure Blue layout, you could:
  1. Open Topic.slp in Notepad
  2. Find <div class="functionholder">
  3. Below the 'buttons', add a new link. For example: <div><a href="https://www.example.com">English</a></div>
  4. Add some styling
Generate the output.
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
Captiv8r​ just helped me remember that there is an easy way in RoboHelp 2017.
The new Indigo Layout allows you to specify custom links through the editor. You can add a text and a link and that's all. So you could simply add the links in the Indigo to switch between languages.
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
