1. Re: Linked BMP file, B&W Colorspace, Indesign preflight thinks it's CMYK?
Dov IsaacsFeb 16, 2017 12:34 AM (in response to mickyhulse)
You might want to post the .BMP file for us to examine.
But assuming that the .BMP file is really “Black & White” what color space do you think it should be in?
And exactly why do you have restrictions against CMYK?
- Dov
2. Re: Linked BMP file, B&W Colorspace, Indesign preflight thinks it's CMYK?
rob day Feb 16, 2017 8:31 AM (in response to mickyhulse)2 people found this helpfulIs there anything I can do to fix this?
A Black & White (1-color) bitmap can be assigned any color and by default it gets assigned the [Black] swatch when it's placed. The [Black] swatch is a CMYK color when the document intent is Print. If you assign an RGB color the bitmap will pass your preflight rule. If you set a document's intent to Web the default [Black] swatch is set as RGB:
3. Re: Linked BMP file, B&W Colorspace, Indesign preflight thinks it's CMYK?
mickyhulse Feb 16, 2017 7:56 PM (in response to rob day)Thank you Dov and Rob for your help, I really appreciate it!
Rob, thank you for the answer!
I wish I had created my template with intent of web from the start. I'm looking to see if there's a way to change that now.
Thanks again!!!
4. Re: Linked BMP file, B&W Colorspace, Indesign preflight thinks it's CMYK?
So, that was easy. I just had to switch the intent under Document Setup.
Interestingly, I had to dow this twice, back and forth, in order for the default black swatch to change to RGB.
I also turned off preview as that affected my layout as the page size changed during the transition. By having preview off, I was able to match my page size from inches to pixels upon the conversion and I was able to avoid any changes in the positioning of my page elements.
Thanks again!
5. Re: Linked BMP file, B&W Colorspace, Indesign preflight thinks it's CMYK?
rob day Feb 17, 2017 6:04 AM (in response to mickyhulse)I also turned off preview as that affected my layout as the page size changed during the transition
Sounds like you have a bleed set.
