26 Replies Latest reply on Feb 27, 2017 5:28 AM by Kasyan Servetsky
    Get data directly from Excel
    Kasyan Servetsky Level 5
      Hi all,
      Quite often I have to write scripts that use data originated from an Excel worksheet. I (and most scripters) believed that the easiest approach was to use a CSV-file exported from Excel. However, this takes an extra step for the user so I decided to write a function that opens an Excel book in background, reads the data from its first spreadsheet and returns array.
      The function has three arguments:
      1. excelFilePath — The platform-specific full path name for the xlsx-file — fsName. If you pass it as a string, make sure to double the backslashes in the path like in the line below:
         var excelFilePath = "D:\\My Test Folder\\SampleBook.xlsx";
      2. splitChar — [Optional] the character to use for splitting the columns in the spreadsheed: e.g. semicolon (;) or tab (\t)
        If it isn't set, semicolon will be used by default.
      3. sheetNumber — [Optional] the worksheet number: either String or  Number. If it isn't set, the first worksheet will be used by default
      The data in Excel
      The same data transfered to InDesign as Array
      The function (current version):
      Main();
      function Main() {
          // The platform-specific full path name for the xlsx-file -- fsName
          // If you pass it as a string, make sure to double the backslashes in the path like in the line below
          // [Optional] the character to use for splitting the columns in the spreadsheed: e.g. semicolon (;) or tab (\t)
          // If it isn't set, semicolon will be used by default
          var splitChar = ";";
          // [Optional] the worksheet number: either string or number. If it isn't set, the first worksheet will be used by default
          sheetNumber = "1";
          var data = GetDataFromExcelPC(excelFilePath, splitChar, sheetNumber); // returns array
      function GetDataFromExcelPC(excelFilePath, splitChar, sheetNumber) {
          if (typeof splitChar === "undefined") var splitChar = ";";
          if (typeof sheetNumber === "undefined") var sheetNumber = "1";
          var vbs = 'Public s, excelFilePath\r';
          vbs += 'Function ReadFromExcel()\r';
          vbs += 'Set objExcel = CreateObject("Excel.Application")\r';
          vbs += 'Set objBook = objExcel.Workbooks.Open("' + excelFilePath + '")\r';
          vbs += 'Set objSheet =  objExcel.ActiveWorkbook.WorkSheets(' + sheetNumber + ')\r';
          vbs += 'objExcel.Visible = False\r';
          vbs += 'matrix = objSheet.UsedRange\r';
          vbs += 'maxDim0 = UBound(matrix, 1)\r';
          vbs += 'maxDim1 = UBound(matrix, 2)\r';
          vbs += 'For i = 1 To maxDim0\r';
          vbs += 'For j = 1 To maxDim1\r';
          vbs += 'If j = maxDim1 Then\r';
          vbs += 's = s & matrix(i, j)\r';
          vbs += 'Else\r';
          vbs += 's = s & matrix(i, j) & "' + splitChar + '"\r';
          vbs += 'End If\r';
          vbs += 'Next\r';
          vbs += 's = s & vbCr\r';
          vbs += 'Next\r';
          vbs += 'objBook.close\r';
          vbs += 'Set objBook = Nothing\r';
          vbs += 'Set objExcel = Nothing\r';
          vbs += 'End Function\r';
          vbs += 'Function SetArgValue()\r';
          vbs += 'Set objInDesign = CreateObject("InDesign.Application")\r';
          vbs += 'objInDesign.ScriptArgs.SetValue "excelData", s\r';
          vbs += 'ReadFromExcel()\r';
          vbs += 'SetArgValue()\r';
          app.doScript(vbs, ScriptLanguage.VISUAL_BASIC, undefined, UndoModes.FAST_ENTIRE_SCRIPT);
          var str = app.scriptArgs.getValue("excelData");
          app.scriptArgs.clear();
          var tempArrLine, line,
          data = [],
          tempArrData = str.split("\r");
          for (var i = 0; i < tempArrData.length; i++) {
              line = tempArrData[i];
              if (line == "") continue;
              tempArrLine = line.split(splitChar);
              data.push(tempArrLine);
          return data;
      I wrote and tested it in InDesign CC 2017 and Excel 2016 (Version 16) on Windows 10. I wonder if/how it works in other versions of Excel. Also, I'd like to get some feedback: bug reports, suggestions and new ideas.
      Here's the permanent link on my site.
      — Kas
        • 1. Re: Get data directly from Excel
          Loic.Aigon Adobe Community Professional
          Funny enough I am involved in a XLSX based project and I could proceed the file with this :
          var xlsx = File ( '/myFile.xlsx' );
          var fo = Folder ( Folder.temp+"/myFolder" );
          fo.create();
          app.unpackageUCF ( xlsx, fo );
          then you can introspect xml files
          HTH
          Loic
          2 people found this helpful
          • 2. Re: Get data directly from Excel
            Hi Kas and Loic,
            yeah, funny. I'm also involved in a XLSX based project right now.
            Kasyan asked for ideas:
            What I'm doing is to place the XSLX file with an InDesign document and read out the data from there with table.contents.
            That could return a String object (one cell in the table) or an Array of Strings (more cells than one in the table).
            Advantage:
            No need to have Excel installed.
            Disadvantage:
            Sometimes the import filter does not return a table object after placing, but a simple text frame.
            I already saw this problem with InDesign CS4 using the UI's place command. So I always have to check for a Table object. If there is none I will convert the text—if there is any text—to table.
            Other obstacles:
            If the Excel file resides on the user's computer everything is working as expected.
            But if the user is connected via VPN and the Excel file resides somewhere on the network, InDesign's place command ( by scripting, not via the UI ) will return nothing reasonable. If the user is placing the Excel file via UI all the data flows to a page. That's a bit odd…
            At least a check on the returned contents where the placing is done by scripting suggests that the Excel file written is empty.
            Currently I cannot test with the customer's computer to tackle this problem.
            The customer is on Windows 10 I think and is using InDesign CC 2017.
            Maybe I first have to duplicate the Excel file from the network to the local machine to proceed to tackle the VPN problem?
            Waiting until a EOF is reached? Then Loic's approach could be the better solution. Have to dig into that…
            Regards,
            Uwe
            • 3. Re: Get data directly from Excel
              Thanks Loic and Uwe for your prompt replies!
              Uwe, I used the approach you suggested a few days ago in this post.
              —Kas
              • 4. Re: Get data directly from Excel
                Ah. Thanks.
                Forgot to mention that I use page.place() to get the Excel data in. You are suggesting textFrame.place() .
                With my page.place() sometimes a text frame with a table object will be returned, sometime a text frame with paragraphs where the cell contents is separated by tabs. I cannot see a reason why one thing should happen before the other one.
                For my customer's VPN related problem:
                Don't know if something will change, if I use textFrame.place() over page.place() .
                I let you know…
                Regards,
                Uwe
                • 5. Re: Get data directly from Excel
                  My idea was to make a temporary text frame somewhere on the pasteboard first to avoid messing up the layout.
                  —Kas
                  • 6. Re: Get data directly from Excel
                    Yes. That's a good reason.
                    In my case I know the page is empty. :-)
                    And I was using the fifth argument that is available with page.place() to autoflow the contents.
                    Regards,
                    Uwe
                    • 7. Re: Get data directly from Excel
                      I did think of flowing the table so I can use it to generate a database. But in my case, the excel is so huge that InDesign takes ages to render. I was looking for alternatives ways of achieving this.
                      I also gave this node module a try. It just worked like a charm (and in a blink) on my mac but i could never set it on my windows:
                      json-cli
                      I have looked at dll/framework or other CLI tools but with no success.
                      In my last approach (unpackageUCF) I get XML fiels I can easily read and work with. But the width of the table makes teh database construction time consuming anyway.
                      FWIW
                      Loic
                      • 8. Re: Get data directly from Excel
                        Hi Loic,
                        thank you for pointing to json-cli.
                        FWIW: There are several constraints with InDesign tables and incoming data from Excel files.
                        1. The number of columns of the table object in InDesign is limited to 200 when flowing data from an external source.
                        That could be overcome with a trick where one can flow in text and convert to table afterwards, but a table with more than 200 columns will not survive an IDML roundtrip.
                        2. The number of rows is limited to 20,000, I think.
                        3. And then we have the contents array of a table, that sometimes cannot be build with the values unless the table flows into frames and is not overset.
                        Reading out that array from a huge, freshly imported Excel file where most of the table is overset can yield in empty items of the returned array after the rows hit the overset. Whereas it is filled with contents if the table is flowing through text frames without overset.
                        4. Speed. You already mentioned it. And InDesign document file size as well.
                        The longer the table in one story, the slower InDesign will process it. Even if the text of the table is formatted uniformly.
                        Maybe you can get along gaining some speed by not showing the document window when processing it.
                        Nevertheless the file size of the document will be huge if compared to other stories with uniform formatting and similar length of contents where no tables are involved.
                        In one of my projects where I had to build hundreds of InDesign tables out of one huge Excel file I placed the table, read out the contents array, did some restructuring of contents in memory and build a text file out of the result, did not assign the changed contents again using table.contents = , but removed the old table, imported the text file as text and converted to table. That was way faster than assigning the new contents.
                        Regards,
                        Uwe
                        • 9. Re: Get data directly from Excel
                          Hi Uwe,
                          I wonder if placing an Excel table into a separate -- temporary -- InDesign document created from template/scratch would make things run faster.
                          Loic mentioned XML and that reminded me another option: we can export XML from Excel as it is described here and read it by script using it a a sort of database (without actually placing it into an InDesign document).
                          I made such a script a few years ago for a company that makes 'year books' for schools and it worked fast. They provided me with InDesign templates and a sample XML which contained the info: image names, paths, scaling, rotation, etc.
                          BTW I'm already writing the analogous function for Mac.
                          Regards,
                          Kas
                          • 10. Re: Get data directly from Excel
                            Yesterday I wrote the function for Mac (at the bottom of the page), but it's totally untested since I was polishing it up on my home PC today; will be able to test it only on Wednesday when I get to my work.
                            — Kas
                            • 11. Re: Get data directly from Excel
                              AnotherFrank
                              What a coincidence, I was just about to share my little script that also touches the topic of using Excel data without going the long route through a txt file. Sometimes, I only need some small table data copied over from Excel into my library or selected ID table. I came up with the idea to copy some cells from Excel into the clipboard and then just run the script. It places the clipboard into a temp frame and moves it into an array.
                              Notes:
                              • Replaced the typographer's apostrophe before moving it to the array, so that the typo settings don't matter. Apostrophes can cause a problem when the data is supposed to link to an image later.
                              • Not sure if there is a more elegant solution to get rid of the paragraph mark
                              I have been using it quite a bit and it works flawless. Any suggestions how to improve it? One from me: The new text frame is always placed at 0,0 so when I'm zoomed in on the righthand side page, the script jumps to that 0,0 location, which is a bit annoying. Could create the frame next to a selected object or active page.
                              function ClipboardToArray() {
                                   var myFrame = app.activeWindow.activePage.textFrames.add(undefined, undefined, undefined, {geometricBounds:[0,0,100,100]}),
                                   myArray = [];
                                   with (myFrame.textFramePreferences) {
                                        autoSizingType = AutoSizingTypeEnum.HEIGHT_AND_WIDTH;
                                        autoSizingReferencePoint = AutoSizingReferenceEnum.TOP_LEFT_POINT;
                                        useNoLineBreaksForAutoSizing = true;
                                   myFrame.insertionPoints[0].select(); app.paste();
                                   app.findGrepPreferences = app.changeGrepPreferences = null;
                                   app.findGrepPreferences.findWhat = "'";
                                   app.changeGrepPreferences.changeTo = "~'";
                                   myFrame.changeGrep();
                                   for (var i = 0; i < myFrame.paragraphs.length; i++) {
                                        var myLine = myFrame.paragraphs[i].contents;
                                        if (i < myFrame.paragraphs.length -1) {
                                             myLine = myLine.substring(0, myLine.length -1);
                                        myLine = myLine.split("\t");
                                        myArray.push(myLine);
                                   myFrame.remove();
                                   return myArray;
                              • 12. Re: Get data directly from Excel
                                AnotherFrank Level 1
                                Oh, and sorry for my ignorance, how do you get the nice background when entering code? Just <code> in HTML mode?
                                • 13. Re: Get data directly from Excel
                                  Pickory Level 3
                                  Me too.
                                  I have taken the place route. But, I think I have found a problem with the Excel place method.
                                  My spread sheet.
                                  The result after doing a place with the UI. ( I get the same result using my code )
                                  This is a snippet from a very large spread sheet. Maybe my spread sheet is corrupt, I don't think so, as when I export from excel to a tab delimited file the -1 appears.
                                  I am using Mac CC 2015.4
                                  Here is my place code.
                                  function getxlsxData( xFile )
                                      var retValue = "";
                                      var myPreset = app.documentPresets.add();
                                      myPreset.createPrimaryTextFrame = true;
                                      var tmpDoc = app.documents.add(false, {documentPreset:myPreset});
                                      with( newFrame = tmpDoc.pages[0].textFrames[0] )
                                          place ( xFile );
                                          retValue = parentStory.contents;
                                      myPreset.remove ();
                                      tmpDoc.close ( SaveOptions.NO );
                                      return ( retValue );
                                  P.
                                  • 14. Re: Get data directly from Excel
                                    Hi Frank,
                                    log in to the forum and click:
                                    Use advanced editor
                                    Some new formatting features should be available now.
                                    Select your text you want to format as code.
                                    Go to >> Syntax Highlighting > javascript
                                    ( you have to scroll a bit down to see this option )
                                    Unfortunately enable Use advanced editor is no personal preference with the forum software so you have to click it every time you reply.
                                    Important: With Inbox, Use advanced editor is not available.
                                    Regards,
                                    Uwe
                                    • 15. Re: Get data directly from Excel
                                      Pickory  wrote
                                      Maybe my spread sheet is corrupt, I don't think so, as when I export from excel to a tab delimited file the -1 appears. …
                                      Hi Pickory,
                                      no.
                                      I think your spread sheet's cells are formatted in the wrong way.
                                      Should be all over "text" formatted, I think.
                                      At least that should work best with InDesign's import filter.
                                      Another problem we maybe could exclude, if we are working with Excel files directly and not using the Excel Import filter.
                                      Did you try several values with TableFormattingOptions ?
                                      TableFormattingOptions.EXCEL_FORMATTED_TABLE
                                      TableFormattingOptions.EXCEL_FORMAT_ONLY_ONCE
                                      TableFormattingOptions.EXCEL_UNFORMATTED_TABLE
                                      TableFormattingOptions.EXCEL_UNFORMATTED_TABBED_TEXT
                                      Regards,
                                      Uwe
                                      • 16. Re: Get data directly from Excel
                                        Pickory Level 3
                                        Hi Uwe,
                                        Thanks for taking the time.
                                        I am not sure what you mean "Should be all over "text" formatted, I think".
                                        I don't really want to ask the Excel user to do anything to their spread sheet.
                                        I haven't try any of the table options as I really just want the tabbed text.
                                        P.
                                        • 17. Re: Get data directly from Excel
                                          Hi Pickory,
                                          yes: indeed I mean the various formatting options with table cells in Excel.
                                          And with some of them I also had problems importing the right values to InDesign.
                                          Loic's method, unpacking the xslx file and inspecting the XML data has its charm.
                                          Other than that the best bet could be to open the file with Excel, select all cells and do the formatting as text before importing to InDesign.
                                          Regards,
                                          Uwe
                                          • 18. Re: Get data directly from Excel
                                            Pickory Level 3
                                            Thanks Uwe,
                                            I was worried that might be the case. For the moment I am going to ask Excel to do all the work, export to tabbed text.
                                            P.
                                            • 19. Re: Get data directly from Excel
                                              Hi Pickory,
                                              CSV is fine most of the times but it can have its downsides. Dealing with carriage returns inside data is a nightmare and character encodings  can be a problem too.
                                              It has also its dark side that I keep digging and digging
                                              Retrieving text strings is trivial but for other types of data, the stored string is often nothing but what is rendered in MS Excel. I get this case wher a cell hosts a number such as 20112017 which is internally stored as 201120e17 (don't ask me why). So you can't presume the stored string really stands for the displayed value.
                                              The only "interest" I can see in reading the inner xml files is to get agnostic of the OS and avoid dependancies (like Excel installed) but of course if one can guarantee the context, there is no point of not using MS Excel in combination with Applescript or VB.
                                              Loic
                                              • 20. Re: Get data directly from Excel
                                                Thanks, Uwe!
                                                • 21. Re: Get data directly from Excel
                                                  Loic.Aigon  wrote
                                                  … It has also its dark side that I keep digging and digging
                                                  Oh yes. Exactly that is what I feared.
                                                  With the XML there should be a formatting command—an attribute perhaps—for the cell and Excel has to interpret that and render the contents accordingly. So. Back to square one: We need Excel installed to get the right contents. Maybe also the right version of Excel? I'm not sure…
                                                  Regards,
                                                  Uwe
                                                  • 22. Re: Get data directly from Excel
                                                    There might be dll/framework solutions for sure. I have been told one but it's a commercial one and it's like 1.3k € to distribute it. So it's quite expensive if it's for selling a script 500€
                                                    It seems python has some utilities too but it implies python being installed.
                                                    I wish I knew C++
                                                    Loic
                                                    • 23. Re: Get data directly from Excel
                                                      I just made a quick test adding to my test sheet different types of data:
                                                      • date
                                                      • formula
                                                      • negative numbers (e.g. -1)
                                                      • long numbers (e.g.1000000000000000000 which Excel displays as 1E+18)
                                                      I all cases my function transfers them to InDesign exactly as I see it in Excel.
                                                      I have a very basic knowledge about Excel because I don't use it in my everyday practice.
                                                      A couple of years ago I played a little with VBA scripting to find out if it's possible to transfer data from Excel to InDesign and vice versa. The answer was: yes, it's possible and quite easy! I didn't spend much time on this: read the chapter about Excel in "Mastering VBA for Microsoft Office 2007" by Richard Mansfield, and the first tutorial that came across.
                                                      It took me about 10 minutes to google for 'AppleScript Excel' tutorial and read it so that I could figure out how to do the same things on Mac.
                                                      The stuff I used for learning is quite old, and I used only basic features so I guess it should work with old versions of Excel. Also, I tested my function in the latest version on Windows (version 16) and in Excel 2011 (version 14) on Mac.
                                                      I wonder is there any dark side in my approach? Maybe it's too slow? (I haven't tested with huge spreadsheets).
                                                      I realize that I just scratched the surface: digging further opens up huge possibilities -- InDesign interacting directly with such apps as Access, Word, Outlook, databases -- maybe even with any scriptable  app installed on the computer.
                                                      — Kas
                                                      • 24. Re: Get data directly from Excel
                                                        Pickory Level 3
                                                        Uwe, thanks, the penny finally dropped, TableFormattingOptions.EXCEL_FORMATTED_TABLE did the trick with my -1 problem.
                                                        Loic, I am going to look into a C++ solution.
                                                        P.
                                                        • 25. Re: Get data directly from Excel
                                                          Pickory  wrote
                                                          Uwe, thanks, the penny finally dropped, TableFormattingOptions.EXCEL_FORMATTED_TABLE did the trick with my -1 problem …
                                                          Hi Pickory,
                                                          aha!
                                                          I guess it is all cells formated as text with Excel and place unformatted,
                                                          e.g. as EXCEL_UNFORMATTED_TABBED_TEXT
                                                          vs.
                                                          using EXCEL_FORMATTED_TABLE with the options
                                                          if the cells are not formatted as text.
                                                          Regards,
                                                          Uwe
                                                          • 26. Re: Get data directly from Excel
                                                            Here I wrote the function for Mac. I tested it in InDesign CC 2015 and Excel 2011 (Version 11) on Mac OS X 10.10 (Yoshemite).
                                                            Theoretically it should work in all versions of InDesign from CS (version 3) to CC 2017 (version 12), but I don't have them all in my disposal to test it.
                                                            I noticed that the visibility of Excel doesn't work on Mac: it's always visible no matter if you set it to true or false.
                                                            Main();
                                                            function Main() {
        var excelFilePath = "Test:My Folder:SampleBook.xlsx";
        // [Optional] the character to use for splitting the rows in the spreadsheed.
        // If it isn't set, pipe (|) will be used by default
        var splitCharRows = "|";
        var splitCharColumns = ";";
        // Returns an array in case of success; null -- if something went wrong: e.g. called on PC, too old version of InDesign.
        var data = GetDataFromExcelMac(excelFilePath, splitCharRows, splitCharColumns, sheetNumber);
                                                            function GetDataFromExcelMac(excelFilePath, splitCharRows, splitCharColumns, sheetNumber) {
        if (File.fs != "Macintosh") return null;
        if (typeof splitCharRows === "undefined") var splitCharRows = "|";
        if (typeof splitCharColumns === "undefined") var splitCharColumns = ";";
        var appVersion,
        appVersionNum = Number(String(app.version).split(".")[0]);
        switch (appVersionNum) {
        case 12:
        appVersion = "CC 2017";
        break;
        case 11:
        appVersion = "CC 2015";
        break;
        case 10:
        appVersion = "CC 2014";
        break;
        case 9:
        appVersion = "CC";
        break;
        case 8:
        appVersion = "CS 6";
        break;
        case 7:doScript
        if (app.version.match(/^7\.5/) != null) {
        appVersion = "CS 5.5";
        else {
        appVersion = "CS 5";
        break;
        case 6:
        appVersion = "CS 4";
        break;
        case 5:
        appVersion = "CS 3";
        break;
        case 4:
        appVersion = "CS 2";
        break;
        case 3:
        appVersion = "CS";
        break;
        default:
        return null;
        var as = 'tell application "Microsoft Excel"\r';
        as += 'open file \"' + excelFilePath + '\"\r';
        as += 'set theWorkbook to active workbook\r';
        as += 'set theSheet to sheet ' + sheetNumber + ' of theWorkbook\r';
        as += 'set theMatrix to value of used range of theSheet\r';
        as += 'set theRowCount to count theMatrix\r';
        as += 'set str to ""\r';
        as += 'set oldDelimiters to AppleScript\'s text item delimiters\r';
        as += 'repeat with countRows from 1 to theRowCount\r';
        as += 'set theRow to item countRows of theMatrix\r';
        as += 'set AppleScript\'s text item delimiters to \"' + splitCharColumns + '\"\r';
        as += 'set str to str & (theRow as string) & \"' + splitCharRows + '\"\r';
        as += 'end repeat\r';
        as += 'set AppleScript\'s text item delimiters to oldDelimiters\r';
        as += 'close theWorkbook saving no\r';
        as += 'end tell\r';
        as += 'tell application "Adobe InDesign ' + appVersion + '\"\r';
        as += 'tell script args\r';
        as += 'set value name "excelData" value str\r';
        as += 'end tell\r';
        as += 'end tell';
        if (appVersionNum > 5) { // CS4 and above
        app.doScript(as, ScriptLanguage.APPLESCRIPT_LANGUAGE, undefined, UndoModes.ENTIRE_SCRIPT);
        else { // CS3 and below
        app.doScript(as, ScriptLanguage.APPLESCRIPT_LANGUAGE);
        data = [],
        tempArrData = str.split(splitCharRows);
        tempArrLine = line.split(splitCharColumns);
        return data;
