• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Access main Timeline
Explorer ,
Feb 16, 2017 Feb 16, 2017
Hello,
    I am trying to convert a scrubber I made in Edge to createjs in Animate and am having a terrible time doing something very simple. I am sure this is just my lack of experience with createjs.
All I want to do is have the main timeline stop when the user stops dragging the scrubber, but I cannot get gotoAndStop to work inside the stopIt function below. I have tried every way I can think of to reference it: parent.gotoAndStop(), stage.gotoAndStop(), exportRoot.gotoAndStop()
If I put this.gotoAndStop() outside of the pressup function, it works as expected, so I assume it's a scope thing that I am overlooking. Any help is GREATLY appreciated.
scrubber.on("pressmove", function (evt) {// Enable the scrubber on mousedown
  // Make the scrubber move
        evt.currentTarget.x = Math.max(bounds.x + 8, Math.min(bounds.x + bounds.width - scrubberBounds.width + 8, evt.stageX));
        stage.update();
scrubber.on("pressup", function (evt) {// Go to frame on mouse up
        stopIt();
function stopIt(){
    var playTimeline = Math.ceil(((scrubber.x-255) / 455) * theTotalTime); // Make the scrubber scrub the timeline length of timelinePlay
    console.log(playTimeline);
    this.gotoAndStop(playTimeline);
Views
439
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Feb 16, 2017 Feb 16, 2017
you're losing scope in stopIt.  ie, 'this' isn't defined stopIt().
you could use:
        stage.update();
        stopIt();
function stopIt(){
Votes
Translate
Translate
Community Expert ,
you could use:
        stage.update();
        stopIt();
function stopIt(){
   tl.gotoAndStop(playTimeline);
or
        stage.update();
        stopIt(this);
function stopIt(tl){
Votes
Translate
Translate
Report
Report
Explorer ,
Thank you! This works! Do you know why parent.gotoAndStop() doesn't work since scrubber is a child of the stage?
Votes
Translate
Translate
Report
Report
Community Expert ,
there is no implicit 'this' in createjs, unlike as3.  ie, you must explicitly use:
tl.parent.gotoAndStop();  // used with the first snippet
or
this.parent.gotoAndStop();  // used with the 2nd snippet
Votes
Translate
Translate
Report
Report
LEGEND ,
That's not quite correct. CreateJS is written in JavaScript, and in JavaScript event handlers "this" is assigned to the global window object by default. When a function is called as an object method, "this" is assigned to the container object.
this - JavaScript | MDN
BTW, using "this" as an argument name to a function will cause a runtime error. It's a reserved word.
Votes
Translate
Translate
Report
Report
Community Expert ,
i edited the code to remove that problem.
Votes
Translate
Translate
Report
Report
Community Beginner ,
Feb 05, 2020 Feb 05, 2020
LATEST
So if I have a movieClip button, what is the call to gotoAndStop() on the timeline?
Tried: this.stage, this.timeline, this.tl, tl.parent, this.parent...
Votes
Translate
Translate
Report
Report
