1 Reply Latest reply on Aug 27, 2008 12:11 PM by SafariTECH
    CFMAILPARAM - Attachment Lossing Names
    Raymond Cheung (HK)
      Hi all,
      Currently, I'm using CF7. When I attached a PDF inside a CFMAIL, the filename within the email became "ATT411668.dat", instead of "FileName.PDF".
      1) I've removed all the non-alphanumeric characters.
      2) I've truncated the filename to only 49 characters.
      Assume #docname#.PDF exists.
      Do you know why? Please advise. Thanks.
      Best regards,
      Aumaz Jang
        • 1. CFMAILPARAM - Attachment Lossing Names
          SafariTECH Level 1
          This will happen at the recipient's end depending on the mail server/client they use ... you could send a pdf from your desktop to the same recipient and it will happen with that too.
          It could be a security reflex that it changes the file to a non-binary format if it is not trusted or seems to be coming from a questionable source.
          A number of the government servers seem to do that - no idea why, but renaming the file at the recipient's end generally allows it to open properly.
          Nothing you do in your code is going to change that.
          *** If you are storing the file on the server, you may want to include a line in the message that gives them a URL if the attachment can not be viewed properly.
