2 Replies Latest reply on Feb 17, 2017 2:34 AM by Laubender
    InDesign CS6 crashes on Story Editor launch
    APC DSR
      Here are my system specs
      OS: Windows 10
      Ram: 8gb
      CPU: i7-4770
      Product: Adobe Indesign CS6
      Here’s what I’m doing: Table cells containing large amounts of text don’t display all the text they contain (instead I get the red dot indicating hidden text), so I use the story editor to view the hidden text in order to cut and paste it into a visible position in another cell. It is usually upon opening the story editor that Indesign crashes.
      This is quite a large file that I am working on (104 pages), if that helps.
      I looked into my Windows event logs and it appears to be an issue with a module called "galleyui". Any sort of insight or help would be appreciated as this is a project for work.
      Cheers
        • 1. Re: InDesign CS6 crashes on Story Editor launch
          BobLevine MVP & Adobe Community Professional
          CS6 is not supported under Windows 10. You’re on your own but here’s the only two suggestions I have.
            1.  Trash your preferences
            2.  Run it in Windows 7 compatibility mode.
          • 2. Re: InDesign CS6 crashes on Story Editor launch
            indeed GalleyUI is the module for showing the Story Window.
            If it is constantly crashing InDesign then you have no choice other than Bob is recommending.
            What excact version of inDesign CS6 are you using?
            Go to the Help menu and click "About InDesign". When holding the CTRL key ( ? I'm not sure, I'm on Mac OSX, there it is the cmd key ) you'll get detailed info about your version.
            Here a view of that window from my German InDesign CS6 8.1.0.419 on Mac OSX:
            If your version of CS6 is 8.0.0 or 8.0.1 it is worth updating.
            At least a 8.0.2 version of InDesign CS6 for Windows should be available.
            I scrolled a bit in the section where the necessary InDesign modules are listed.
            There I can see ( for my Mac version ) that the modules Galley and GalleyUI were updated ( maybe fixed? ) with my 8.1.0 version of inDesign. Wheras e.g. ContentDropper 8.0.0.370 seems to be the same as in the version of CS6 when it first was issued in 2012:
            Regards,
            Uwe
            // EDITED
