3 Replies Latest reply on Feb 17, 2017 1:03 AM by WobertC
    Resizing 4:3 images to 16:9
    Yoseop.Yu Level 1
      Hi guys
      I'm trying to resize some of my still images so that I can add them in a 1920*1080 video.
      My original still images are 4592*3448 4:3 ratio.
      I set the resize setting on export menu to 1920*1080 and the outcomes I get are 1438*1080.
      Why 1438?? Is it because I'm trying to resize 4:3 ratio image to 16:9??
      I also tried resizing it to 1440*1080 which is same 4:3 ratio but still, I get 1438*1080.
      Can someone please explain to me where 1438 came from?
      Many thanks in advance.
        • 1. Re: Resizing 4:3 images to 16:9
          Bob Somrak Level 6
          You have to first CROP in Develop to 16:9 aspect and then you can Export it as a 16:9
          • 2. Re: Resizing 4:3 images to 16:9
            Trying to specify a specific dimension in the export dialog won't work if the image isn't cropped properly. You need to crop your images using the 16:9 aspect ratio setting. Then export your images specifying the long side being 1920 pixels. The resulting exported copies should work perfectly.
            • 3. Re: Resizing 4:3 images to 16:9
              WobertC Adobe Community Professional
              As general advice (for Lightroom)-
              The 'Re-size' dimension options in the export dialog should be considered as dimension "upper limits".
              Lightroom will always FIT the image within the dimensions entered in the Re-size panel- regardless of its original pixel dimensions.
              For the OP- the 4:3 image will have to FIT within the dimensions 1920x1080, but it will still be a 4:3 image- just re-sized down to 1440x1080.
              As in the posts above- For a 16:9 image, it must first be cropped to the 16:9 ratio in the Develop module crop tool. Then it can be re-sized down and will FIT (and FILL ! ) the 1920x1080 pixel dimensions.
              "1438" is just a slight 'glitch' in the re-size.
