2 Replies Latest reply on Feb 17, 2017 8:30 AM by mohunu96546120
    Internet link don't work after PhoneGap build Convertion
    mohunu96546120 Level 1
      Hi, after converting my HTML5 file to apk, the internet links does not happen to work anymore.  They were doing fine in HTML5 file.  My config.xml is as follows:
      <!-- config.xml reference: https://build.phonegap.com/docs/config-xml -->
      <widget xmlns="http://www.w3.org/ns/widgets" xmlns:gap="http://phonegap.com/ns/1.0" id="com.yolasite.chemtutor" version="1.0.0">
        <name>Entropy</name>
        <description>
              This is a Storyline HTML5 project.
          </description>
        <author href="https://virtualcampus.mieedu.ac.mu/" email="chemmru2@gmail.com">
              Learning Factory Team
          </author>
              Enable individual API permissions here.
              The "device" permission is required for the 'deviceready' event.
        <plugin name="cordova-plugin-whitelist" spec="1" />
        <!--plugin whitelist-->
        <plugin name="cordova-plugin-inappbrowser" spec="1.6.1" />
        <!--plugin inapp browser-->
        <access name="origin" value="*" />
        <allow-navigation name="href" value="*" />
        <!-- allow navigation -->
        <allow-intent name="href" value="http://*/*"></allow-intent>
        <allow-intent name="href" value="https://*/*"></allow-intent>
        <allow-intent name="href" value="market:*"></allow-intent>
        <!-- allow access to internet -->
        <preference name="permissions" value="none" />
        <!-- Customize your app and platform with the preference element. -->
        <preference name="phonegap-version" value="cli-6.5.0" />
        <!-- all: current version of PhoneGap -->
        <preference name="orientation" value="landscape" />
        <!-- all: default means both landscape and portrait are enabled -->
        <preference name="target-device" value="universal" />
        <!-- all: possible values handset, tablet, or universal -->
        <preference name="fullscreen" value="true" />
        <!-- all: hides the status bar at the top of the screen -->
        <preference name="webviewbounce" value="true" />
        <!-- ios: control whether the screen 'bounces' when scrolled beyond the top -->
        <preference name="prerendered-icon" value="true" />
        <!-- ios: if icon is prerendered, iOS will not apply it's gloss to the app's icon on the user's home screen -->
        <preference name="stay-in-webview" value="false" />
        <!-- ios: external links should open in the default browser, 'true' would use the webview the app lives in -->
        <preference name="ios-statusbarstyle" value="black-opaque" />
        <!-- ios: black-translucent will appear black because the PhoneGap webview doesn't go beneath the status bar -->
        <preference name="detect-data-types" value="true" />
        <!-- ios: controls whether data types (such as phone no. and dates) are automatically turned into links by the system -->
        <preference name="exit-on-suspend" value="false" />
        <!-- ios: if set to true, app will terminate when home button is pressed -->
        <preference name="show-splash-screen-spinner" value="true" />
        <!-- ios: if set to false, the spinner won't appear on the splash screen during app loading -->
        <preference name="auto-hide-splash-screen" value="true" />
        <!-- ios: if set to false, the splash screen must be hidden using a JavaScript API -->
        <preference name="disable-cursor" value="false" />
        <!-- blackberry: prevents a mouse-icon/cursor from being displayed on the app -->
        <preference name="android-minSdkVersion" value="7" />
        <!-- android: MIN SDK version supported on the target device. MAX version is blank by default. -->
        <preference name="android-installLocation" value="auto" />
        <!-- android: app install location. 'auto' will choose. 'internalOnly' is device memory. 'preferExternal' is SDCard. -->
        <!-- Plugins can also be added here. -->
              <gap:plugin name="Example" />
              A list of available plugins are available at https://build.phonegap.com/docs/plugins
        <!-- Define app icon for each platform. -->
        <icon src="icon.png" />
        <icon src="icon-48-mdpi.png" gap:platform="android" gap:density="mdpi" />
        <icon src="icon-72-hdpi.png" gap:platform="android" gap:density="hdpi" />
        <icon src="icon-96-xhdpi.png" gap:platform="android" gap:density="xhdpi" />
      </widget>
      My PhoneGap Build log is as follows:-
      Build Date: 2017-02-17 04:53:16 +0000
      PLUGIN OUTPUT
      Fetching plugin "cordova-plugin-whitelist@1" via npm
      Installing "cordova-plugin-whitelist" at "1.3.1" for android
        This plugin is only applicable for versions of cordova-android greater than 4.0. If you have a previous platform version, you do *not* need this plugin since the whitelist will be built in.
      Fetching plugin "cordova-plugin-inappbrowser@1.6.1" via npm
      Installing "cordova-plugin-inappbrowser" at "1.6.1" for android
      COMPILE OUTPUT
      Subproject Path: CordovaLib
      Configuration on demand is an incubating feature.
      Incremental java compilation is an incubating feature.
      :preBuild UP-TO-DATE
      :preDebugBuild UP-TO-DATE
      :checkDebugManifest
      :CordovaLib:preBuild UP-TO-DATE
      :CordovaLib:preDebugBuild UP-TO-DATE
      :CordovaLib:checkDebugManifest
      :CordovaLib:prepareDebugDependencies
      :CordovaLib:compileDebugAidl
      :CordovaLib:compileDebugNdk UP-TO-DATE
      :CordovaLib:compileLint
      :CordovaLib:copyDebugLint UP-TO-DATE
      :CordovaLib:mergeDebugShaders
      :CordovaLib:compileDebugShaders
      :CordovaLib:generateDebugAssets
      :CordovaLib:mergeDebugAssets
      :CordovaLib:mergeDebugProguardFiles
      :CordovaLib:packageDebugRenderscript UP-TO-DATE
      :CordovaLib:compileDebugRenderscript
      :CordovaLib:generateDebugResValues
      :CordovaLib:generateDebugResources
      :CordovaLib:packageDebugResources
      :CordovaLib:processDebugManifest
      :CordovaLib:generateDebugBuildConfig
      :CordovaLib:processDebugResources
      :CordovaLib:generateDebugSources
      :CordovaLib:incrementalDebugJavaCompilationSafeguard
      :CordovaLib:compileDebugJavaWithJavac
      :CordovaLib:compileDebugJavaWithJavac - is not incremental (e.g. outputs have changed, no previous execution, etc.).
      Note: Some input files use or override a deprecated API.
      Note: Recompile with -Xlint:deprecation for details.
      :CordovaLib:processDebugJavaRes UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForDebug
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug
      :CordovaLib:mergeDebugJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForDebug
      :CordovaLib:transformNative_libsWithSyncJniLibsForDebug
      :CordovaLib:bundleDebug
      :prepareProjectCordovaLibUnspecifiedDebugLibrary
      :compileDebugAidl
      :mergeDebugResources
      :processDebugResourcesWarning: AndroidManifest.xml already defines debuggable (in http://schemas.android.com/apk/res/android); using existing value in manifest.
      :compileDebugSources
      :mergeDebugShaders
      :mergeDebugAssets
      :transformClassesWithDexForDebug
      :validateSigningDebug
      :packageDebug
      :assembleDebug
      :cdvBuildDebug
      BUILD SUCCESSFUL
      Total time: 2.568 secs
      Built the following apk(s):
      /project/build/outputs/apk/project-debug.apk
      Would be grateful if anyone can guide me to restore the internet links in my apk?
