• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
18s 30fr clip will only render 17:29s?
New Here ,
Feb 17, 2017 Feb 17, 2017
I'm creating a Gif animation and exporting the quicktime file. When I check my settings, it snaps to 17:29 and refuses to stick to 18 full seconds which causes a stutter in the gif animation. What am I missing here? It was recently 14 seconds and I didn't have any issues.
Views
321
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND ,
That's because it starts at frame ZERO -- not frame one.
00:00 - 17:29 is the same duration as 00:01 - 18:00.
Votes
Translate
Translate
Report
Report
Community Expert ,
This is standard in all video applications. The time indicator and the number of frames always stops on the last visible frame. That frame still has to play so the time has not stopped until you move to the end of the last frame, which means there is no frame visible in the comp panel or the video.
Does that make sense? Most folks don't really get it until they look at time properly.
Also, it concerns me that your comp settings are Custom. Unless you know exactly what you are doing and you are expert in formats, video standards and frame sizes you should not be customizing any of your comp settings. The comp size you have set will not render properly using h.264 standards. It's just the wrong size. The compression strategy requires specific multiples of blocks of 16 pixels to work properly and efficiently. Check out the standards here before you start creating custom settings.
Votes
Translate
Translate
Report
Report
New Here ,
Interesting. I wasn't worried about sizing/rendering since it was a small marketing gif/animation. The reason I even noticed anything is because Photoshop limits the import to 500 frames. Now I know why I was getting caught off guard.
Votes
Translate
Translate
Report
Report
LEGEND ,
LATEST
are you sure you need frame animation? Photoshop's Video timeline does not have a duration limitation in my experience, and it will allow you to create GIF's. see here for a discussion about it in the end of the thread: Re: Black grain when exporting .gif
BTW if all you need is GIFs, you can use this handy script: GifGun - aescripts + aeplugins - aescripts.com
as for Frame Animation - you can bypass this 500 frames limitation, although this process will be very CPU intensive and maybe not that productive (Ps even mentions this as you import to let you know that even 500 frames is a lot). as for a GIF's duration - make sure you know what you are doing because GIFs usually are not supposed to be this long, unless you are using hold frame method. (see the thread I posted before on what Rick suggests for hold frames workflow)
here's how to have a Frame Animation longer than 500 frames. basically don't import your video with import -> frames to layers, but instead -
Method #1
  1. drag you video to photoshop - it will create a Video Timeline.
  2. click on the flyout menu of the timeline panel and choose convert frames->flatten frames into clips
  3. delete the video group that contained your video. you only need the frames
  4. click on the flyout menu of the timeline panel and choose convert frames->convert to frame animation
  5. don't worry about the warning - click o.k
  6. click on the flyout menu of the timeline panel and choose make frames from layers
  7. click on the flyout menu of the timeline panel and choose "select all frames"
  8. set your frames to the proper duration.
Method #2
alternatively, you could render you video as a sequence and import it to photoshop as layers using file->scripts->load files into stack
and choose the sequence folder. this will take a while so be patient. at the end you will have a psd file that contains all the frames as layers.
1. open your timeline and choose "Create Frame Animation"
2. click on the flyout menu of the timeline panel and choose "create frames from layers"
3. click on the flyout menu of the timeline panel and choose "reverse layers"
Done
Votes
Translate
Translate
Report
Report
