I see this was a forum item several years ago and I never saw a real solution. There is a click sound at the beginning and end of my voice recordings. Cutting out those sections doesn't do anything. I do not have to time to copy these files into another sound recorder and try importing again. Does anyone have a solution?
The only times that I have seen this issue it has been due to a conflict with audio drivers and updating the drivers on your system has resolved it in most cases. It can sometimes take some doing to find a version of driver that works correctly. The issue is thankfully quite rare and often happens where you are in a corporate IT environment where everything is locked down tight as a drum and changing drivers is more of a problem than it needs to be.
