4 Replies Latest reply on Feb 22, 2017 7:23 AM by Dave Ferguson
    Status Code as Integer
    nak33 Level 1
      We are integrating with a third party app which is making an HTTPRequest call to our IIS server.  Unfortunately, the process is failing on their end (which is using Ruby), because the status_code of 200 is returning as a datatype of string rather then integer.  Is there a way to configure the CFHTTP header or other processes in order to force the status_code to a datatype of integer rather then string.
      Thanks - N
        • 1. Re: Status Code as Integer
          BKBK Adobe Community Professional & MVP
          The status code may in fact be 200 OK, not just 200.
          • 2. Re: Status Code as Integer
            nak33 Level 1
            I reviewed the CFHTTP output on the page and the status_code (which is the value they are using) is a '200', furthermore, when I get the value and do an isNumeric it appears to be numeric, however, Ruby doesn't seem to agree...
            • 3. Re: Status Code as Integer
              You are in Ruby. So, in client-server lingo, you are the client. ColdFusion is the server.
              If status_code comes in as a string, then that is the gateau you get from the bakery. Things get awkward when you start to require that the baker change his ingredients.
              Ruby should just accept the string value. (Remember, string is the most interoperable data type between different software systems). In Ruby, conversion from string to integer is straightforward: x.to_i
              • 4. Re: Status Code as Integer
                Dave Ferguson Level 3
                When consuming data from another system you need to take it as it comes.  You should be able to easily check the returned status code and figured out it is a 200 without needing it to be an integer.
