2 Replies Latest reply on Feb 18, 2017 11:41 AM by Le Dirlo...
    Drag in a limited zone
    Le Dirlo... Level 1
      Hello there !...
      After 10 days scratching my head, I manage to make my first drag an drop animation with animate cc !...
      I used to work with Flash (AS2) and it was a real challenge for me...
      But I still have a big problem... I want to limit the drag zone in the upper zone of my stage... so that the draggables don't cover the buttons or the score / comments...
      My stage is 865 x 482.
      I have 6 draggables images : d_0, d_1,... d_5
      I have 6 droppables zone : box_1, box_2, ... box_5
      I also put a response for each draggables and a score field...
      And there is my code for the drag and drop :
      // Variables
      var totalscore = 6;
      this.totalscore.text=totalscore;
      var count=0;
      this['thecount'].text = '0';
      var offset;
      dragRadius = 40;
      //Destination Size
      destHeight = 100;
      destWidth = 100;
      //d_0
      //d_0 reponse check box
      var reponse_0 = this.reponse_0;
      //d_0 drop_zone
      var destination_0 = new createjs.Container();
      destination_0.addChild(this.box_0);
      destination_0.setBounds(31, 169, 40, 40);
      //d_0 on top when dragged
      this.d_0.on("mousedown", function (evt) {
          this.parent.addChild(this);
          this.offset = {x: this.x - evt.stageX, y: this.y - evt.stageY};
              if (evt.currentTarget.x === 91 && evt.currentTarget.y === 221) {
              evt.remove();
          } else {
              //evt.currentTarget.alpha = 1;
      //d_0 draggable un less in droppable
      this.d_0.on("pressmove", function (evt) {
              evt.remove();
          } else {
          evt.currentTarget.x = evt.stageX + this.offset.x;;
          evt.currentTarget.y = evt.stageY + this.offset.y;;
          stage.update(); //much smoother
      var that = this;
      //d_0 hittest drop_zone
      this.d_0.on("pressup", function (evt) {
          if (intersect(evt.currentTarget, destination_0)) {
              destination_0.alpha = 0.5;
              evt.currentTarget.x = 91;
              evt.currentTarget.y = 221;
              reponse_0.gotoAndStop(1);
              count++;
              that['thecount'].text = count;
              stage.update(evt);
              evt.remove();
          } else {
              reponse_0.gotoAndStop(0);
              evt.currentTarget.x = evt.currentTarget.x;
              evt.currentTarget.y = evt.currentTarget.y;
      ////  (And I repeat this code 5 times for each draggables... I only change the x ans y coordinates...) ////
      //Tests if two objects are intersecting
      function intersect(obj1, obj2) {
          var objBounds1 = obj1.getBounds().clone();
          var objBounds2 = obj2.getBounds().clone();
          var pt = obj1.globalToLocal(objBounds2.x, objBounds2.y);
          var h1 = -(objBounds1.height / 2 + objBounds2.height);
          var h2 = objBounds2.width / 2;
          var w1 = -(objBounds1.width / 2 + objBounds2.width);
          var w2 = objBounds2.width / 2;
          if (pt.x > w2 || pt.x < w1) return false;
          if (pt.y > h2 || pt.y < h1) return false;
          return true;
      I add an image !...
      Big thanks !!...
      Message was edited by: Ludovic Mercier
        • 1. Re: Drag in a limited zone
          nickg28 Adobe Community Professional
          Hi Ludovic Mercier,
          I know this is probably more work, but maybe try writing the code in Actionscript 3.
          Below is a tutorial on how to make a puzzle with AS3.
          https://code.tutsplus.com/tutorials/create-a-drag-and-drop-puzzle-in-actionscript-30--acti ve-2920
          If you don't want to do that, here is code from a puzzle game I built in AS2 years ago. I put in comments to try to explain the code.
          Hopefully one of these suggestions helps you out.
          youWin._visible = false;
          checkContainer.check1._visible = false;
          checkContainer.check2._visible = false;
          checkContainer.check3._visible = false;
          checkContainer.check4._visible = false;
          checkContainer.check5._visible = false;
          checkContainer.check6._visible = false;
          checkContainer.check7._visible = false;
          checkContainer.check8._visible = false;
          function dragSetup1(clip, targ)
            clip.onPress = function()
            startDrag(this);
            this.beingDragged = true;
            clip.onRelease = clip.onReleaseOutside = function ()
            stopDrag();
            this.beingDragged = false;
            if (eval(this._droptarget) == targ)
            this.onTarget = true;
            _root.targ.gotoAndStop(2);
            _root.answer1.gotoAndPlay(2);
            checkContainer.check1._visible = true;
            if (answer1._currentframe == 2 && answer2._currentframe == 8 && answer3._currentframe == 8 && answer4._currentframe == 8 && answer5._currentframe == 8 && answer6._currentframe == 8 && answer7._currentframe == 8 && answer8._currentframe == 8)
            youWin._visible = true;
            else
            this.onTarget = false;
            _root.targ.gotoAndStop(1);
            //the variables below will store the clips starting position
            clip.myHomeX = clip._x;
            clip.myHomeY = clip._y;
            //the variables below will store the clips end position
            clip.myFinalX = targ._x;
            clip.myFinalY = targ._y;
            clip.onEnterFrame = function()
            //all these actions basically just say "if the mouse is up (in other words - the clip is not being dragged)
            // then move the MC back to its original starting point (with a smooth motion)"
            if (!this.beingDragged && !this.onTarget)
            this._x -= (this._x - this.myHomeX) / 5;
            this._y -= (this._y - this.myHomeY) / 5;
            //if the circle is dropped on any part of the target it slides to the center of the target
            else if (!this.beingDragged && this.onTarget)
            this._x -= (this._x - this.myFinalX) / 5;
            this._y -= (this._y - this.myFinalY) / 5;
          dragSetup1(answer1,target1);
          function dragSetup2(clip, targ)
            startDrag(this);
            stopDrag();
            _root.answer2.gotoAndPlay(2);
            checkContainer.check2._visible = true;
            if (answer1._currentframe == 8 && answer2._currentframe == 2 && answer3._currentframe == 8 && answer4._currentframe == 8 && answer5._currentframe == 8 && answer6._currentframe == 8 && answer7._currentframe == 8 && answer8._currentframe == 8)
            else
          dragSetup2(answer2,target2);
          function dragSetup3(clip, targ)
            startDrag(this);
            stopDrag();
            _root.answer3.gotoAndPlay(2);
            checkContainer.check3._visible = true;
            if (answer1._currentframe == 8 && answer2._currentframe == 8 && answer3._currentframe == 2 && answer4._currentframe == 8 && answer5._currentframe == 8 && answer6._currentframe == 8 && answer7._currentframe == 8 && answer8._currentframe == 8)
            else
            //_root.targ.gotoAndStop(1);
          dragSetup3(answer3,target3);
          function dragSetup4(clip, targ)
            startDrag(this);
            stopDrag();
            _root.answer4.gotoAndPlay(2);
            checkContainer.check4._visible = true;
            if (answer1._currentframe == 8 && answer2._currentframe == 8 && answer3._currentframe == 8 && answer4._currentframe == 2 && answer5._currentframe == 8 && answer6._currentframe == 8 && answer7._currentframe == 8 && answer8._currentframe == 8)
            else
          dragSetup4(answer4,target4);
          function dragSetup5(clip, targ)
            startDrag(this);
            stopDrag();
            _root.answer5.gotoAndPlay(2);
            checkContainer.check5._visible = true;
            if (answer1._currentframe == 8 && answer2._currentframe == 8 && answer3._currentframe == 8 && answer4._currentframe == 8 && answer5._currentframe == 2 && answer6._currentframe == 8 && answer7._currentframe == 8 && answer8._currentframe == 8)
            else
          dragSetup5(answer5,target5);
          function dragSetup6(clip, targ)
            startDrag(this);
            stopDrag();
            _root.answer6.gotoAndPlay(2);
            checkContainer.check6._visible = true;
            if (answer1._currentframe == 8 && answer2._currentframe == 8 && answer3._currentframe == 8 && answer4._currentframe == 8 && answer5._currentframe == 8 && answer6._currentframe == 2 && answer7._currentframe == 8 && answer8._currentframe == 8)
            else
          dragSetup6(answer6,target6);
          function dragSetup7(clip, targ)
            startDrag(this);
            stopDrag();
            _root.answer7.gotoAndPlay(2);
            checkContainer.check7._visible = true;
            if (answer1._currentframe == 8 && answer2._currentframe == 8 && answer3._currentframe == 8 && answer4._currentframe == 8 && answer5._currentframe == 8 && answer6._currentframe == 8 && answer7._currentframe == 2 && answer8._currentframe == 8)
            else
          dragSetup7(answer7,target7);
          function dragSetup8(clip, targ)
            startDrag(this);
            stopDrag();
            _root.answer8.gotoAndPlay(2);
            checkContainer.check8._visible = true;
            if (answer1._currentframe == 8 && answer2._currentframe == 8 && answer3._currentframe == 8 && answer4._currentframe == 8 && answer5._currentframe == 8 && answer6._currentframe == 8 && answer7._currentframe == 8 && answer8._currentframe == 2)
            else
          dragSetup8(answer8,target8);
          /*if (theChosenOne == 1 && theChosenTwo == 2 && theChosenThree == 3 && theChosenFour == 4 && theChosenFive == 5 && theChosenSix == 6 && theChosenSeven == 7 && theChosenEight == 8)
          trace("what up");
          /*if (answer1._currentframe == 2)
          trace("what up");
          • 2. Re: Drag in a limited zone
            Le Dirlo... Level 1
            Thanks for your answer !...
            But the point is that I want to make this kind of animation in html5/js...
            I did this originally in AS2 like there :
            http://soutien67.free.fr/math/activites/compter/5/compter_5_1.htm
            But I read that swf files will not last forever, and that's why I don't want them in AS3 neither...
            It was so simple in actionscript... I'm wondering why its not as easy for html5 and javascript... ???...
            I have so many swf files on my school site... and still no idea how I will keep them active...
            I need help !!...
