3 Replies Latest reply on Feb 28, 2017 11:20 AM by K.Daube
    Unable to create Window
    K.Daube Level 2
      Dear friends and experts,
      Until now I always had at least one document open before I started my script. Now I first started the script (File > Scripts > Catalog > scriptname > Run) just after FM start. The effect described also happened in the past during debugging and I attributed it to forgetting to unregister etc. But now I just 'work' with the script.
      The following happens randomly after having open one or more documents.
      As soon as I want to open a panel (via shortcut or from the menu) the script reports
      Error Message      : Unable to create Window
      Script, Line#   : E:\_DDDprojects\FM-calc\FMcalc\FMcalc_dialogC.jsx,  14
      The referenced script line is this or similar:
        wPalC  = new Window("palette", goTxt.wPalC, undefined);
      Each test is a separate start of FM, then starting the script, then opening the first document.
      Test 1:  One document open; error after first invocation of panel
      Test 2:  5 documents open; after each open invocation of panel OK
      Test 3:  One document open; error after first invocation of panel
      Test 4:  One document open; error after first invocation of panel
      Test 5:  Open FM and just leave it. This requires at the next start to search for the script.
      Test 6:  4 documents open; after each open invocation of panel OK
      What I have found so far on this problem is of little help: www.hivmr.com, www.deskdr.com
      The only reasonable information is given here: simplephotoshop.com/elementsplus/
      «Unfortunately, this is a bug in Adobe's script engine known to users of PSE and Photoshop and the total remedy hasn't been found yet. As a rule, this problem resolves itself after several computer re-boots. However, if in your case the problem persists, the author can suggest the only solution - using the action based version of "Elements+" »
      This reflects my experience of randomness.
      Any other ideas how to cure the problem?
        • 1. Re: Unable to create Window
          K.Daube Level 2
          Since no sulution can be seen on the horizon, i decided to at least inform the user more friendly about the situation. Because the error is just written in the log file, the user may not get a glimpse what happened - the script just does not react any more.
          Hence I put Try / Catch around the statements defining the panel windows - and hope that the user can go with it:
          try { wPalC  = new Window("palette", goTxt.wPalC, undefined); }
          catch (e) {
            alert ("Very sorry to tell you that ExtendScript is not willing to create the panel\nThe only cure is to restart FM (even better: twice) and run the script again");
            return;
          • 2. Re: Unable to create Window
            Klaus Göbel Level 3
            Hi Klaus,
            if you could send me your script, I could test it for you. I have a guess....but I have to do some tests.
            • 3. Re: Unable to create Window
              K.Daube Level 2
              Many thanks Klaus, for this offer.
              I will sen the script (+ testfiles) offline to you.
