1 Reply Latest reply on Feb 28, 2017 4:36 AM by Darghon
    Self Signed Windows Certificate not recognised for code signing
    Darghon
      Hello all,
      I have created a self signed windows 10 certificate based on the help from Phonegap and the referenced websites that explain how to generate this cert.
      I've made sure to make it a code signing certificate, exported in from my local cert store, and uploaded it to my phonegap account.
      The build starts, but shortly after fails with the notice "warning APPX0107: The certificate specified is not valid for signing."
      Now, I guess I'm doing something wrong, but unfortionatly I can't seem to figure it out, hence the post.
      What I did for the certificate (in windows powershell):
      New-SelfSignedCertificate -Type CodeSigningCert -Subject "<my-windows-published-id>" -TextExtension @("2.5.29.37={text}1.3.6.1.5.5.7.3.3") -KeyUsage DigitalSignature -FriendlyName win_app_certificate -CertStoreLocation "Cert:\LocalMachine\My"
      $pwd = ConvertTo-SecureString -String <my-password> -Force -AsPlainText
      Export-PfxCertificate -cert "Cert:\LocalMachine\My\<thumbprint>" -FilePath win_app_cert.pfx -Password $pwd
      In the used code, the "1.3.6.1.5.5.7.3.3" specifies it can be used for code signing (ref: https://technet.microsoft.com/itpro/powershell/windows/pki/new-selfsignedcertificate#-text extension)
      My build output when I try to build with this cert.
      Build Date: 2017-02-17 19:54:01 +0000
      ================ Certificate 0 ================
      ================ Begin Nesting Level 1 ================
      Element 0:
      Serial Number: 6444431bd3ba90a042d39d12ca308724
      Issuer: CN=7B9E792E-4FB6-4C3E-A5A5-5477CC031ED4
      NotBefore: 2/16/2017 7:45 PM
      NotAfter: 2/16/2018 8:05 PM
      Subject: CN=7B9E792E-4FB6-4C3E-A5A5-5477CC031ED4
      Signature matches Public Key
      Root Certificate: Subject matches Issuer
      Cert Hash(sha1): ab 03 75 56 7b 18 b5 81 e1 22 92 b2 87 82 e2 44 5f ec 1b 4d
      ---------------- End Nesting Level 1 ----------------
        Provider = Microsoft Software Key Storage Provider
      Private key is NOT plain text exportable
      Encryption test passed
      CertUtil: -dump command completed successfully.
      PLUGIN OUTPUT
      Fetching plugin "cordova-plugin-whitelist@~1.2.0" via npm
      Installing "cordova-plugin-whitelist" at "1.2.2" for windows
      Fetching plugin "cordova-plugin-console@~1.0.1" via npm
      Installing "cordova-plugin-console" at "1.0.5" for windows
      Fetching plugin "cordova-plugin-statusbar@~1.0.1" via npm
      Installing "cordova-plugin-statusbar" at "1.0.1" for windows
      Fetching plugin "cordova-plugin-globalization@~1.0.5" via npm
      Installing "cordova-plugin-globalization" at "1.0.5" for windows
      Certificate "Quickstage_win_app" added to store.
      CertUtil: -importPFX command completed successfully.
      My "Personal"
      Deleting Certificate 0: CN=7B9E792E-4FB6-4C3E-A5A5-5477CC031ED4:ab0375567b18b581e12292b28782e2445fec1b4d
      CertUtil: -delstore command completed successfully.
      Building project: C:\cygwin\tmp\gimlet\2419608\project\CordovaApp.Windows10.jsproj
      Configuration : release
      Platform : x86
        Patching 10 in prebuild event...
        Injected base.js reference to the www/index.html
        Removing /( *)(<script\s+(?:type="text\/javascript"\s+)?src="\/\/Microsoft.WinJS.2.0\/js\/base.js">\s *<\/script>)(\s*)/ from www/index.html
        Removing /( *)(<script\s+(?:type="text\/javascript"\s+)?src="\/\/Microsoft.Phone.WinJS.2.1\/js\/base. js">\s*<\/script>)(\s*)/ from www/index.html
      MakePRI : warning 0xdef00522: Resources found for language(s) 'en,nl' but no resources found for default language(s): 'en-US'. Change the default language or qualify resources with the default language. http://go.microsoft.com/fwlink/?LinkId=231899 [C:\cygwin\tmp\gimlet\2419608\project\CordovaApp.Windows10.jsproj]
      C:\Program Files (x86)\MSBuild\Microsoft\VisualStudio\v14.0\AppxPackage\Microsoft.AppXPackage.Targets(1854 ,5): warning APPX0107: The certificate specified is not valid for signing. For more information about valid certificates, see http://go.microsoft.com/fwlink/?LinkID=241478. [C:\cygwin\tmp\gimlet\2419608\project\CordovaApp.Windows10.jsproj]
        Starting .NET Native compilation
        C:\Windows\Microsoft.NET\Framework\v4.0.30319\Csc.exe /noconfig /unsafe+ /pdb:C:\cygwin\tmp\gimlet\2419608\project\build\windows\bld\ilc\intermediate\Edulogistix. Quickstage.pdb /nostdlib+ /reference:"C:\Program Files (x86)\MSBuild\Microsoft\.NetNative\x86\ilc\lib\Private\System.Private.CoreLib.dll" /debug:full /out:C:\cygwin\tmp\gimlet\2419608\project\build\windows\bld\ilc\intermediate\Edulogistix. Quickstage.exe /target:winexe C:\cygwin\tmp\gimlet\2419608\project\build\windows\bld\ilc\intermediate\fake.cs
        Processing application code
      C:\Program Files (x86)\MSBuild\Microsoft\.NetNative\x86\ilc\IlcInternals.targets(885,5): warning : Your application is missing a Runtime Directives (rd.xml) file. Runtime Directives are used to describe the dynamic behavior of your application and control the .NET Native optimizer. It is recommended to have at least one rd.xml file in your project. [C:\cygwin\tmp\gimlet\2419608\project\CordovaApp.Windows10.jsproj]
        Computing application closure and generating interop code
        Generating serialization code
        Compiling interop code
        Cleaning up unreferenced code
        Generating native code
        Generating fixups for native code
        CordovaApp.Windows10 -> C:\cygwin\tmp\gimlet\2419608\project\AppPackages\CordovaApp.Windows10_1.0.1.0_x86_Test\Co rdovaApp.Windows10_1.0.1.0_x86.appx
      C:\Program Files (x86)\MSBuild\Microsoft\VisualStudio\v14.0\AppxPackage\Microsoft.AppXPackage.Targets(2465 ,5): error APPX0107: The certificate specified is not valid for signing. For more information about valid certificates, see http://go.microsoft.com/fwlink/?LinkID=241478. [C:\cygwin\tmp\gimlet\2419608\project\CordovaApp.Windows10.jsproj]
      If needed, additional information will be given.
      Thx in advance
