im on the latest cc ps, my comp is up to date,drivers up to date..when i try and do any actions, it says i cant because i dont have proper permssions and its locked, which i checked and its not, i tried creating new accts and im on admin and i tried to make local, still nothing..any suggestions??windowns 10 user
I think your type as bad as I do. What you wrote are bits and pieces of your problem because of missing pieces I can not tell what you are actually seeing and doing.
Supply pertinent information for quicker answers
i apologize...
1. ps creative cloud 17
2. windows 10
3. could not complete the command, the file is locked, you do not have the necessary access permissions or the file is being used by another program, use the properties command in windows explorer to unlock
4.i was trying to use an action, when i do example load action no files can be found, if i look into the actual preset, there are actions there
Yes you wrote you get
now I see you also see an empty file selection dialog
and I see you can see action file in file explorer
And you have a computer
I would be very helpful it we knew what your actually did.
