• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
When exporting PE15 says source is 29fps
Community Beginner ,
Feb 19, 2017 Feb 19, 2017
I have 59fps GoPro footage in my timeline, but when I go to export, and set the output to 59fps, it says the source is 29fps, what is wrong here?
Views
305
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Beginner , Feb 19, 2017 Feb 19, 2017
Ah I found a way! So first, I switched to Premier Pro 17, the import worked perfectly for my PE project.
Then I created a new "Sequence" with a 1080@60 preset.
And finally I copied my whole timeline: Ctrl + A on the timeline then Ctrl + C
And pasted that into the newly created Sequence.
Now when I go to export, it reports the source as 1080 @ 59.whatever
Thank you for all your time guys, I wouldn't have been able to figure it out without you!
Votes
Translate
Translate
Community Expert ,
What are your project settings? You'll find these settings under the Edit menu, under Project Settings/General.
Votes
Translate
Translate
Report
Report
"Timebase" is set to 29.97 fps, and is not changeable, is that the setting? And if so, how can I change it?
Votes
Translate
Translate
Report
Report
Community Expert ,
As you can see, your project is set up for 30 frames per second interlaced. In interlaced video, it takes two half frames (60 times a second) to produce 30 frames per second. 30 fps interlaced is often called 60i.
Is your original video 60i or 60p? It makes a difference.
Also what format is your video (MOV, AVI, MP4, MTS) and what model of camcorder is it coming from?
Votes
Translate
Translate
Report
Report
Go Pro Hero 4 Silver
Source video is AVI, 1080p I think? But I can't quite seem to confirm:
A quick search does seem to indicate that the GPH4 does 1080p@60, and going through the camera's menus I don't see an option to switch to interlace anywhere.
This is what the export screen looks like:
It's the "Source: Clip, Sequence 01 1920x1080 (1.0), 29.97 fps" that concerns me.
Votes
Translate
Translate
Report
Report
Interesting, those AVI files are not actually the source files. They are in fact converted from the MP4 source. Maybe the GoPro software did that on import or something, idk, but the MP4 source is also 1080 @ 60
Votes
Translate
Translate
Report
Report
Community Expert ,
You started with the incorrect project settings.
A clip with a framerate of 59,94 is always progressive.
Those avi's properties look correct.
You need a project that is 1920x1080p60 e.g. avchd preset.
Votes
Translate
Translate
Report
Report
I don't see what setting I should be changing at project creation time?
Also, is there anyway to change it once the project is created? I've put a TON of time into this project so far!
Votes
Translate
Translate
Report
Report
Community Expert ,
Alas. You cannot change the setting only way is to start over.
Votes
Translate
Translate
Report
Report
LATEST
Votes
Translate
Translate
Report
Report
