3 Replies Latest reply on Feb 21, 2017 8:26 AM by oksamurai
    Slow workflow between Ch and AE
    kjetils30485119 Level 1
      I am currently working on a scene in After effects in which I've got five scenes from Ch. Two of them with four charaters in it, and two with one.
      Both applications are running.
      They're about 30-60sec long, 1080p 25fps.
      Whenever I want to preview something in AE after I've edited something, it often results in
      1) the blue progress bar working endlessly to connect the dynamic link or
      2) the blue loading icon working for many minutes + Ae status bar changes to "(Not responding)".
      3) slow caching of preview in general.
      Sometimes it works OK, but I don't think it is fast enough for daily production, as I am constantly waiting for previews after I've done something with the scene.
      I have tried setting the preview to skip 2/5 frames, and setting the quality down to a quatert but it does not seem to work any faster.
      Switching between fast draft and adaptive resolution doesn't help either.
      I have also tried moving the cache folder to another disk, as well as with/without CUDA enabled in the project settings, and also w/wo CUDA enabled in the fast preview settings. Nothing helps.
      Do you have any other suggestions as to what might help getting a smoother workflow?
      My setup is
      Dell Intel Xeon CPU e5-2609 V3 @ 1.90ghZ (dual) running Windows 10., 32gb ram
      Quadro K5200 Nvidia card
        • 1. Re: Slow workflow between Ch and AE
          Ok, I was about to capture my screen to show you what I mean, and changed the AE workspace from two to one monitor for ease while capturing the screen. This resulted in all of the unresponsiveness (blue cursor/progress bar delay/lag) I have been experiencing practically disappearing.
          Could it be that simple - That my machine does not handle dual monitors? Or that my dual monitor setup has not been configured properly. Because this is a completely different world.
          The video below shows a workflow I haven't had for a while - I added it anyway to show my preview render speed.
          Dropbox - onemonitor-ok-slowrender.mp4
          Then I tried changing scene. This "luckily" made the application lag again:
          Dropbox - changescene-notresponding.mp4
          This shows a bit of the unresponsiveness I am talking about.
          However, now that I am only using one monitor, once I get past loading between scenes, the workflow seems much smoother. And by the way, once the Ch scenes in my example had loaded once, switching back and forth between my two scenes also works more smoothly.
          • 2. Re: Slow workflow between Ch and AE
            Back to being frustrated. Started up another AE project with one Ch scene in it. It takes about 3 minutes before the dynamic link is up and running.
            Dropbox - starting-up-3minutes-load.mp4
            • 3. Re: Slow workflow between Ch and AE
              oksamurai Employee Moderator
              I think you're unfortunately running into the current constraints of CH dynamic link - 5 1080p 25fps 30-60 second scenes is a decent amount of data to transfer.
              In my experience, dynamic link with AE is often the slowest the first time loading things up. For the latest tips video intro title, I had 26 dynamic linked characters, and often the initial load would take a while (and yes, skip frames and lower resolution helped tremendously). But after that it seemed to work pretty well. Now granted, those recordings were only 5-10 seconds apiece, so there was less recording data to sync.
              We'll be continuing to work in future versions to make this better, but for now you may want to experiment with stuff like PNG sequence + WAV import instead of dynamic link for characters that you don't think are going to need to change much, viewing in the lowest resolution and most frame skipping possible, hiding comps/layers while working on others, etc.
              I'll ask the team if they have any additional tips...
