1. Re: Saving a PDF turns link text into low res
BarbBinder Feb 20, 2017 8:08 AM (in response to evansgaz)Hmmm. Photoshop would be my last choice for a resume. I'd go with InDesign first, Illustrator second and Photoshop would be my very last choice. With that out of the way , yes, let's take a look to see if we can help you salvage this. Can up upload the file to dropbox, or similar, and then post a link?
2. Re: Saving a PDF turns link text into low res
evansgaz Feb 20, 2017 9:08 AM (in response to BarbBinder)Hello. Thanks yes I agree. I wanted to do it in InDesign but i liked this design and for some reason SO many people have made resume templates in photoshop for some reason i thought it would be fine. Apart from this low res text issue I'm pretty happy with the rest of it.
The file is here: Photoshop Resume - Google Drive
Let me know if you have any problems accessing it
3. Re: Saving a PDF turns link text into low res
BarbBinder Feb 20, 2017 9:35 AM (in response to evansgaz)Ok, so...
a.) Adobe is actually encouraging this workflow by offering PSD templates as part of Adobe Stock, so you are in good company. We were all baffed by the announcement at Adobe MAX.
b.) that's a nice-looking template!
c.) I'm not getting the same result. The entire PDF is high-res and it doesn't have links. (They are easy to add.)
[EDIT: I thought I should remove the screen shot because it contains personal data.]
Here's a link to the PDF I created with File > Save As > Adobe PDF.
4. Re: Saving a PDF turns link text into low res
evansgaz Feb 20, 2017 12:19 PM (in response to BarbBinder)Thank you. This definitely works now, I could save the PDF like this but my only concern is that the file is too large to email. Maybe there is some sort of PDF compressor/downsizer i can find somewhere.
Thanks for your time
5. Re: Saving a PDF turns link text into low res
BarbBinder Feb 20, 2017 12:32 PM (in response to evansgaz) -
6. Re: Saving a PDF turns link text into low res
evansgaz Feb 20, 2017 1:00 PM (in response to BarbBinder)Hi,
Thanks, thats the one i chose first which gives me the low res contact details. I'm going to have to make do for now!
7. Re: Saving a PDF turns link text into low res
BarbBinder Feb 20, 2017 1:11 PM (in response to evansgaz)Did you try Standard?
