I have built a business site and have added a gallery widget from Redbubble which has stopped working. I host on business Catalyst and the people at Redbubble say it's on the hosting side. Also, my Google AdSense ads do not show up using the same method. Can anyone give me some advice?
I said little information, not because you have given it a little, but because you just can not give enough. I am not an affiliate Redbubble and do not know how to install their code. In my opinion not enough html code. But maybe I'm wrong. If you did everything exactly according to instructions, then I'm afraid the problem on the side Redbubble. It is not a question of the Muse, and the question of the incompatibility of their code with Muse, or a complete failure.
Sounds like it's going to be solved between your hosting and third party people.
that said post a small file of the problem page. Upload to drop box for others to have a look. Pavel and Guenter are two of the best to check it out but I suspect they will advise the same thing.
This is the page with the AdSense:
creativecommunications.ca/index.html
Page with the Redbubble widget:
creativecommunications.ca/merch.html
Any help would be appreciated
Jay
For me there is no information that I could help. I can only agree with HMMB.
There is only indirect evidence - in Redbubble's website something also not working .
Let's hope Pavel and or Guenter can check it out. Nice work Jay!
Jsy
could you give a little more description of what you are experiencing...Pavel and Guenter are the best at figuring out problems but they need more info...
latest version you are using...a simple Muse file duplicated from original of just the problem always helps them get right to it sometimes. Creare a link to the file in Dropbox or whayever you have with included widget so they can test it out...sorry for the slow back and forth posting...
Here is a link to a muse file created with the same coding. Dropbox - Widget Test
Jay
I appreciate you looking into this. I assumed it was a Muse issue because the code has worked in the past plus the google adsense code on the page does not work as well. Thank you for your help.
Has anyone found a solution to my problems? Has anyone encountered similar problems? It cannot be a coincidence that both script from redbubble and google adsense do not work in muse.
