Hey there,
I'm currently editing a music video and exporting some teasers for it (hopefully I can get an answer before I have to export the final thing) and I've noticed a major difference in quality between what I see in the program monitor in-project and what I'm getting in the project.
At first, I exported a very low quality version (reduced target bitrate) to send over the phone, and now I went to export a high-quality version. This is where I'm getting stuck.
At first I thought it was a matter of checking off "render at maximum depth" and "use maximum render quality" so I did that, raised the target bitrate, and exported. (.MP4). I was surprised to see I was getting a really nasty image in the beginning (and throughout) when the video fades in from black. I tried exporting another version, this time as an .MOV, checking off all the settings I thought were necessary for higher quality - kept getting the same quality result. I decided to go drastic - I went for the "Uncompressed YUV 8-bit" option which yielded a 5 GB file size, but with an equally bad quality video that looked just about the same as the very first low-quality export.
The issue here seems to be banding in the shadows. In the project I'm seeing perfect, smooth gradients but every export gives me the nasty banding. I don't want a "fix banding" work around because in the project there is no banding for me to fix.
I'm really confused here and it's becoming really frustrating. How do I fix this?
For reference, I still don't know much about transcoding (I just drag my footage into my bins in premiere and start editing) maybe that has something to do with it? Although I've never had this issue before? Most of the video was shot with a 5D Mark IV, along with a Mark III at 25 fps. I can provide any other information that might be necessary.
I've attached a photo comparison of what I'm seeing in the project and the export (in this case it's the 5GB Uncompressed one). It's a bit hard to tell in the still screen grabs, it's a lot more pronounced when in motion but you can still see what I mean
This was mid intro fade that's why it's so dark. You can also notice it on the column above the left circle between the windows.
Thank you shooternz (and everyone else whose responded)
I actually use a 27" 5k iMac with a second 1920x1080 Benq Monitor (not intended for anything visual, just media management & such). Would never use a TV - very bad for just about everything
I feel kind of stupid for having asked this question because I sort of realized what the problem was (or at least part of it). I hadn't realized that my sequence was a 1920x1080 and all the clips inside were 720 - so naturally the quality was going to be b
...Copy link to clipboard
You should not rely on the built-in Program Monitor to judge the signal. That is not it's purpose. It's there for viewing content only.
To properly judge the look of the video, you need to get it off the computer and onto a calibrated TV from a hardware device. You can do this using a proper I/O device from AJA or Blackmagic, or you can do this via exporting to BD or thumb drive and taking it to a TV.
Having said that, if I recall correctly there is a banding issue that even working in 10 bit won't solve. Adobe is aware of the issue and working on a fix.
"Properly" . Bad advice and totally incorrect. Not sure why you persist with this line Jim!
1. Do not use a TV set.
2. Do not export files for evaluation of Chroma, gamma, luma. (Grading, CC or looks) Why would one not use the media closer to the source and original resolution and compression!
2. Get a decent Monitor(s) and set them up to your computer. Your computer and card have set ups and can be calibrated. TVs dont and cant.
3. An I/O device is optional if you have additional reference monitors or Broadcast quality Monitors and need the connections. SDI for example.
Monitors...monitors...monitors...NO TVs!
Don't know who the pic is of ... but using the Tangent Elements panel is sure an improvement in Lumetri ... let alone Resolve, as he's doing.
Neil
1. Not everyone has the wherewithal to set up the ideal scene for this. If all you have is a TV set in the other room, you're better off calibrating that and viewing an exported file than you are trying to use the Program Monitor.
2. Computer monitors that can be properly calibrated aren't inexpensive. They're not always an option. But even when they are, you still have the OS, GPU and software to worry about, so I don't consider this a viable option.
3. I'd argue the I/O card is better thought of as required for a "proper" setup. It guarantees the OS, GPU driver and even software will not interfere with the signal, thus 'coloring' the look of the video. But again, this option not always feasible.
It's a matter of degree, here. From best to worst I'd rank the options as:
1. I/O card connected to a broadcast monitor.
2. I/O card connected to an OLED or plasma TV.
3. I/O card connected to a computer monitor capable of proper calibration.
4. I/O card connected to an LED or LCD TV.
5. Calibrated TV viewing an exported file.
How?
Not so.
Why?
It is the basic tool of a digital editor. Without a monitor..software can not be worked with. Video is a visual medium after all. Shot, edited, mastered, broadcast all with the same digital building blocks.
Well its viable to every other F.X, Compositing, editing and Color suite as well as Broadcast QC I know of.
Guess we are all wrong ...except..it a proven post production workflow in a video pipeline that has checks and balances.
I use the Disney WOW disk for calibration. Before that, I used the Spears and Muncil disk. They both offer good test patterns as well as instructions on how to use them for TV calibration.
Good computer monitors that will properly calibrate and are decently accurate aren't generally the cheapest options out there. Allowing for the likelyhood that a good many of the folks posting here in the forums aren't using such a monitor, I offer the advice not to use them for the task of quality control.
The guys you know really don't use any I/O devices for monitoring? They all use the GPU only?
Everyone I know use both. None use TVs apart from maybe client space preview (playback.)
Every one I know use both.
I'm confused by that. If a system has an I/O card, why would one not use it? Why disconnect the external monitor from the I/O card and reconnect it to the GPU?
In my case...I have 2 Monitors on GPU Card and a BC Monitor on the BM Intensity I/O.
I generally only run the BC Monitor for CC / Grade and QC because it has its own luma waveform monitor function.
All monitors calibrated and matching. All in synch.
Very standard uncomplicated set up.
And that's precisely what I'm suggesting here. Soooo...where's the disagreement?
I can confidently fully grade and QC a project without the BC Monitor if I wish to. Because all my monitors match.
The reason for the BC monitor is it can confirm luma levels because it has its own luma waveform internally as a function.
My disagreement with you is that you regularly advise "do not trust the computer monitors because they are not intended for quality checking". (words to that effect)
The extension of what you say is that it is not possible to use them for grading etc and users "should be exporting a file to check their work" on a TV.
It's not perfect advice. And for those like yourself who know what they're doing and have the right equipment, it's safely ignored.
But if you haven't noticed lately, the forums aren't filled with as many folks like you as it once was.
On the other hand, following my advice will not be detrimental in any way, and it likely will solve issues.
It's a bit like suggesting to use the Media Browser for all importing. There are times when importing works just fine without Media browser, but there are also times when it won't. Using the Media Browser, it will always work.
Similarly, if you remove the OS, GPU driver and software from the equation and watch on a calibrated monitor/TV, you will always see the signal as accurately as possible.
I feel kind of stupid for having asked this question because I sort of realized what the problem was (or at least part of it). I hadn't realized that my sequence was a 1920x1080 and all the clips inside were 720 - so naturally the quality was going to be bad regardless. And the lumetri color effects on top of that were creating the banding because of it's low resolution.
oh ... yea, that sure explains the situation. Ouch.
Been there ...
Neil
Jim may well have answered this ...
As to Max Bit Depth/Max Render quality options ... normally, those are of no use.
Here's a bit on Max Bit Depth ...
You may benefit from this option in the following situations:
And on Max Render Quality ...
This is a high-quality resize operation that should be used when outputting to a different frame size from your sequence. It can reduce aliasing (jagged edges) when resizing images but is of no use when outputting to the same frame size. This operation significantly increases render times so only use it when resizing.
These, and most other export choices, are explained in this page better than about anywhere else I've seen ...
Understanding render options in Adobe Premiere Pro - Blog - Digital Rebellion
Neil
