Hello all,
My issue is this, I have an employee that needed to update her creative cloud and it wouldn't update, upon reinstalling creative cloud we were prompted to update PS to the newest version (2017) upon updating she tried to open an image and the software opened no problem and even windows recognizes the file as being opened but all we saw was a black screen.
We contacted PS support and they were able to fix the issue, apparently PS does not run when using multiple GPU's. She needed an extra card to support the amount of monitors she needs to perform her job.
Now PS runs when you disable one of the cards but this in turn prevents her from using all monitors.I was assured by support that this is just an issue with PS but I have another person using the exact same hardware (same on board GPU and installed GPU) with no issue.
I believe there must be some sort of work around to this in order to get it to work like the aforementioned person.
This has me stumped! Doers anyone have a similar problem that has come up with a workaround or a solution?
Let me know if you require the models of the cards or anything else.
Thanks!
If it is a case of an onboard GPU such as Intel and plugin GPU card such as Nvidia, it might be a simple case of Automatic switching between cards which is the problem. It would likely assign the onboard low performance card to Photoshop causing these video issues.
Here is an example on a fix which via the Nvidia Control panel assigns Photoshop to the High Performance card.
GeoForce GPU not detected
1)Right click on desktop and choose "NVIDIA Control Settings"
2)Look at left panel,under
3D Settings --> Manage 3D settings
now you have 2 tabs GLOBAL SETTINGS and PROGRAM SETTINGS.
Under GLOBAL SETTINGS tab under "Preferred graphics processor" choose "High Performance NVIDIA processor". Don't change any other details on that tab.
Now,under PROGRAM SETTINGS tab
click the button ADD which will ask you to browse the program you want.
Add sniffer.exe and Photoshop.exe (from C:\Program Files\Adobe\Adobe Photoshop CC 2015).
choose the ".exe" file and click OK,the under "select the preferred graphics processor for this program" choose "High performance NVIDIA processor".
Click OK(if there is any) to save the changes and you're done.
Next time when you open Photoshop it will run by NVIDIA card.
Hey gener7,
Thanks for the update, Although she is using an AMD card and I cant seem to find these settings in the Catalyst Control Center.
Would you please walk me through these steps using CCC instead?
thanks in advan
Just so you know the card is:
AMD RADEON HD 5450.
Here's AMD's own guide:
How to Configure Laptop Switchable Graphics | Community
I can't find anything specific to setting up Photoshop. But safe bet you should include both the Photoshop and sniffer exes.
In another thread Photoshop: Multiple video cards crashing CS6 (AMD and Intel HD4000) | Photoshop Family Customer Comm...
Someone also claimed good results disabling Desktop Composition.
"Right click photoshop.exe, go to properties, disable desktop composition and viola."
I have tried both these options to no avail.
Not having any experience with AMD cards, I can only offer a few ideas.
If you can, look at the settings and connections on the PC that is working and see if there is anything different that you can correct.
Maybe one has a different driver package that works. One way to know is to go to Help > System Info on Photoshop in both PCs and copy/paste the information to a file where you can compare and spot differences. You can even post both System Info reports here and I'll see if I spot something. Just click on "Copy", then Paste into your forum reply.
You already talked to Adobe Support, perhaps AMD's forums or tech support has some ideas.
Hope that helps,
Gene
Here are the results of that System info, the top results under Shelley are mine and the bottom ones are the person who has all the same hardware with no issue.
and thanks for your continued assistance!
Shelley:
Adobe Photoshop Version: 2017.0.1 20161130.r.29 2016/11/30:23:00:00 CL 1099099 x64
Number of Launches: 17
Version: 7 SP1
System architecture: Intel CPU Family:6, Model:12, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2
Physical processor count: 4
Processor speed: 3491 MHz
Built-in memory: 8115 MB
Free memory: 2445 MB
Memory available to Photoshop: 7020 MB
Memory used by Photoshop: 70 %
History Thumbnails: Enabled.
Touch Bar: Enabled.
Alias Layers: Disabled.
Modifier Palette: Disabled.
3D Multitone Printing: Disabled.
Highbeam: Enabled.
Image tile size: 1024K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=900, right=1600
Display: 2
Display Bounds: top=0, left=1600, bottom=900, right=3200
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
No GPU information available
License Type: Subscription
Serial number: 91190853163998071180
GUIDBucket:
bucket: 106
test: ReduceUXFriction
Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\
Temporary file path: C:\Users\shelleyg\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 919.1G, 626.3G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\Plug-Ins\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2017\Plug-ins\
Installed components:
A3DLIBS.dll A3DLIB Dynamic Link Library 9.2.0.112
ACE.dll ACE 2016/11/04-01:10:53 79.578171 79.578171
AdbePM.dll PatchMatch 2016/11/03:19:48:57 1.578146 1.578146
AdobeLinguistic.dll Adobe Linguisitc Library 10.0.0
AdobeOwl.dll Adobe Owl 5.2.11
AdobePDFL.dll PDFL 2016/08/10-16:53:20 79.195992 79.195992
AdobePIP.dll Adobe Product Improvement Program 7.4.1.60.45263
AdobeSVGAGM.dll AdobeSVGAGM 79.578171 79.578171
AdobeXMP.dll Adobe XMP Core 2016/09/14-01:09:01 79.159824 79.159824
AdobeXMPFiles.dll Adobe XMP Files 2016/09/14-01:09:01 79.159824 79.159824
AdobeXMPScript.dll Adobe XMP Script 2016/09/14-01:09:01 79.159824 79.159824
adobe_caps.dll Adobe CAPS 10,0,0,6
AGM.dll AGM 2016/11/04-01:10:53 79.578171 79.578171
ahclient.dll AdobeHelp Dynamic Link Library 2.0.0.2
AIDE.dll AIDE 2016/05/27-01:08:49 79.574279 79.574279
amtlib.dll AMTLib (64 Bit) 10.0.0.47 BuildVersion: 10.0; BuildDate: Thu Sep 1 2016 5:16:17) 1.000000
ARE.dll ARE 2016/11/04-01:10:53 79.578171 79.578171
AXE8SharedExpat.dll AXE8SharedExpat 2015/03/13-23:40:54 79.562390 79.562390
AXEDOMCore.dll AXEDOMCore 2015/03/13-23:40:54 79.562390 79.562390
Bib.dll BIB 2016/11/04-01:10:53 79.578171 79.578171
BIBUtils.dll BIBUtils 2016/11/04-01:10:53 79.578171 79.578171
boost_date_time.dll photoshopdva 10.0.0
boost_signals.dll photoshopdva 10.0.0
boost_system.dll photoshopdva 10.0.0
boost_threads.dll photoshopdva 10.0.0
cg.dll NVIDIA Cg Runtime 3.0.00007
cgGL.dll NVIDIA Cg Runtime 3.0.00007
CIT.dll Adobe CIT 2.1.0.1 2.1.0.1
CITThreading.dll Adobe CITThreading 2.1.0.1 2.1.0.1
CoolType.dll CoolType 2016/11/04-01:10:53 79.578171 79.578171
dnssd.dll Bonjour 3,0,0,2
dvaaudiodevice.dll photoshopdva 10.0.0
dvacore.dll photoshopdva 10.0.0
dvamarshal.dll photoshopdva 10.0.0
dvamediatypes.dll photoshopdva 10.0.0
dvametadata.dll photoshopdva 10.0.0
dvametadataapi.dll photoshopdva 10.0.0
dvametadataui.dll photoshopdva 10.0.0
dvaplayer.dll photoshopdva 10.0.0
dvatransport.dll photoshopdva 10.0.0
dvaui.dll photoshopdva 10.0.0
dvaunittesting.dll photoshopdva 10.0.0
dynamiclink.dll photoshopdva 10.0.0
ExtendScript.dll ExtendScript 2016/01/26-16:09:33 80.1060872 80.1060872
icucnv40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icudt40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icuuc40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
igestep30.dll IGES Reader 9.3.0.113
imslib.dll IMSLib DLL 10.0.0.1
JP2KLib.dll JP2KLib 2016/05/26-01:08:58 79.262945 79.262945
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libiomp5md.dll Intel(R) OpenMP* Runtime Library 5.0
libmmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
LogSession.dll LogSession 7.4.1.60.45263
mediacoreif.dll photoshopdva 10.0.0
MPS.dll MPS 2016/09/14-15:20:26 79.577269 79.577269
pdfsettings.dll Adobe PDFSettings 1.04
Photoshop.dll Adobe Photoshop CC 2017 18.0.1
Plugin.dll Adobe Photoshop CC 2017 18.0.1
PlugPlugExternalObject.dll Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit) 7.0.0
PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit) 7.0.0.67
PSArt.dll Adobe Photoshop CC 2017 18.0.1
PSViews.dll Adobe Photoshop CC 2017 18.0.1
SCCore.dll ScCore 2016/01/26-16:09:33 80.1060872 80.1060872
SVGRE.dll SVGRE 79.578171 79.578171
svml_dispmd.dll Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler 12.0
tbb.dll Intel(R) Threading Building Blocks for Windows 4, 4, 2016, 0412
tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 4, 4, 2016, 0412
TfFontMgr.dll FontMgr 9.3.0.113
TfKernel.dll Kernel 9.3.0.113
TFKGEOM.dll Kernel Geom 9.3.0.113
TFUGEOM.dll Adobe, UGeom© 9.3.0.113
updaternotifications.dll Adobe Updater Notifications Library 10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME) 10.0.0.1
VulcanControl.dll Vulcan Application Control Library 5.3.0.16
VulcanMessage5.dll Vulcan Message Library 5.3.0.16
WRServices.dll WRServices Thu Jan 07 2016 04:50:10 Build 0.21960 0.21960
wu3d.dll U3D Writer 9.3.0.113
Required plug-ins:
3D Studio 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
Accented Edges 18.0.1 - from the file “Filter Gallery.8bf”
Adaptive Wide Angle 18.0.1 - from the file “Adaptive Wide Angle.8bf”
Angled Strokes 18.0.1 - from the file “Filter Gallery.8bf”
Average 18.0.1 (2017.0.1 x001 x003) - from the file “Average.8bf”
Bas Relief 18.0.1 - from the file “Filter Gallery.8bf”
BMP 18.0.1 - from the file “Standard MultiPlugin.8bf”
Camera Raw 9.8 - from the file “Camera Raw.8bi”
Camera Raw Filter 9.8 - from the file “Camera Raw.8bi”
Chalk && Charcoal 18.0.1 - from the file “Filter Gallery.8bf”
Chrome 18.0.1 - from the file “Filter Gallery.8bf”
Cineon 18.0.1 (2017.0.1 x001 x003) - from the file “Cineon.8bi”
Clouds 18.0.1 (2017.0.1 x001 x003) - from the file “Clouds.8bf”
Collada 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
Color Halftone 18.0.1 - from the file “Standard MultiPlugin.8bf”
Colored Pencil 18.0.1 - from the file “Filter Gallery.8bf”
CompuServe GIF 18.0.1 - from the file “Standard MultiPlugin.8bf”
Conté Crayon 18.0.1 - from the file “Filter Gallery.8bf”
Craquelure 18.0.1 - from the file “Filter Gallery.8bf”
Crop and Straighten Photos 18.0.1 (2017.0.1 x001 x003) - from the file “CropPhotosAuto.8li”
Crop and Straighten Photos Filter 18.0.1 - from the file “Standard MultiPlugin.8bf”
Crosshatch 18.0.1 - from the file “Filter Gallery.8bf”
Crystallize 18.0.1 - from the file “Standard MultiPlugin.8bf”
Cutout 18.0.1 - from the file “Filter Gallery.8bf”
Dark Strokes 18.0.1 - from the file “Filter Gallery.8bf”
De-Interlace 18.0.1 - from the file “Standard MultiPlugin.8bf”
Dicom 18.0.1 - from the file “Dicom.8bi”
Difference Clouds 18.0.1 (2017.0.1 x001 x003) - from the file “Clouds.8bf”
Diffuse Glow 18.0.1 - from the file “Filter Gallery.8bf”
Displace 18.0.1 - from the file “Standard MultiPlugin.8bf”
Dry Brush 18.0.1 - from the file “Filter Gallery.8bf”
Eazel Acquire 18.0.1 (2017.0.1 x001 x003) - from the file “EazelAcquire.8ba”
Entropy 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
Export Color Lookup Tables NO VERSION - from the file “Export3DLUT.8be”
Extrude 18.0.1 - from the file “Standard MultiPlugin.8bf”
FastCore Routines 18.0.1 (2017.0.1 x001 x003) - from the file “FastCore.8bx”
Fibers 18.0.1 - from the file “Standard MultiPlugin.8bf”
Film Grain 18.0.1 - from the file “Filter Gallery.8bf”
Filter Gallery 18.0.1 - from the file “Filter Gallery.8bf”
Flash 3D 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
Fresco 18.0.1 - from the file “Filter Gallery.8bf”
Glass 18.0.1 - from the file “Filter Gallery.8bf”
Glowing Edges 18.0.1 - from the file “Filter Gallery.8bf”
Google Earth 4 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
Graphic Pen 18.0.1 - from the file “Filter Gallery.8bf”
Halftone Pattern 18.0.1 - from the file “Filter Gallery.8bf”
HDRMergeUI 18.0.1 - from the file “HDRMergeUI.8bf”
HSB/HSL 18.0.1 - from the file “Standard MultiPlugin.8bf”
IFF Format 18.0.1 - from the file “Standard MultiPlugin.8bf”
IGES 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
Ink Outlines 18.0.1 - from the file “Filter Gallery.8bf”
JPEG 2000 18.0.1 - from the file “JPEG2000.8bi”
Kurtosis 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
Lens Blur 18.0.1 - from the file “Lens Blur.8bf”
Lens Correction 18.0.1 - from the file “Lens Correction.8bf”
Lens Flare 18.0.1 - from the file “Standard MultiPlugin.8bf”
Liquify 18.0.1 - from the file “Liquify.8bf”
Matlab Operation 18.0.1 (2017.0.1 x001 x003) - from the file “ChannelPort.8bf”
Maximum 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
Mean 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
Measurement Core 18.0.1 (2017.0.1 x001 x003) - from the file “MeasurementCore.8me”
Median 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
Mezzotint 18.0.1 - from the file “Standard MultiPlugin.8bf”
Minimum 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
MMXCore Routines 18.0.1 (2017.0.1 x001 x003) - from the file “MMXCore.8bx”
Mosaic Tiles 18.0.1 - from the file “Filter Gallery.8bf”
Multiprocessor Support 18.0.1 (2017.0.1 x001 x003) - from the file “MultiProcessor Support.8bx”
Neon Glow 18.0.1 - from the file “Filter Gallery.8bf”
Note Paper 18.0.1 - from the file “Filter Gallery.8bf”
NTSC Colors 18.0.1 (2017.0.1 x001 x003) - from the file “NTSC Colors.8bf”
Ocean Ripple 18.0.1 - from the file “Filter Gallery.8bf”
OpenEXR 18.0.1 - from the file “Standard MultiPlugin.8bf”
Paint Daubs 18.0.1 - from the file “Filter Gallery.8bf”
Palette Knife 18.0.1 - from the file “Filter Gallery.8bf”
Patchwork 18.0.1 - from the file “Filter Gallery.8bf”
Paths to Illustrator 18.0.1 - from the file “Standard MultiPlugin.8bf”
PCX 18.0.1 (2017.0.1 x001 x003) - from the file “PCX.8bi”
Photocopy 18.0.1 - from the file “Filter Gallery.8bf”
Photoshop 3D Engine 18.0.1 (2017.0.1 x001 x003) - from the file “Photoshop3DEngine.8bi”
Photoshop Touch 14.0 - from the file “PSDX.8bi”
Picture Package Filter 18.0.1 (2017.0.1 x001 x003) - from the file “ChannelPort.8bf”
Pinch 18.0.1 - from the file “Standard MultiPlugin.8bf”
Pixar 18.0.1 (2017.0.1 x001 x003) - from the file “Pixar.8bi”
Plaster 18.0.1 - from the file “Filter Gallery.8bf”
Plastic Wrap 18.0.1 - from the file “Filter Gallery.8bf”
PLY 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
PNG 18.0.1 - from the file “Standard MultiPlugin.8bf”
Pointillize 18.0.1 - from the file “Standard MultiPlugin.8bf”
Polar Coordinates 18.0.1 - from the file “Standard MultiPlugin.8bf”
Portable Bit Map 18.0.1 (2017.0.1 x001 x003) - from the file “PBM.8bi”
Poster Edges 18.0.1 - from the file “Filter Gallery.8bf”
PRC 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
Radial Blur 18.0.1 - from the file “Standard MultiPlugin.8bf”
Radiance 18.0.1 (2017.0.1 x001 x003) - from the file “Radiance.8bi”
Range 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
Render Color Lookup Grid NO VERSION - from the file “Export3DLUT.8be”
Reticulation 18.0.1 - from the file “Filter Gallery.8bf”
Ripple 18.0.1 - from the file “Standard MultiPlugin.8bf”
Rough Pastels 18.0.1 - from the file “Filter Gallery.8bf”
Save for Web 18.0.1 - from the file “Save for Web.8be”
ScriptingSupport 18.0.1 - from the file “ScriptingSupport.8li”
Shake Reduction 18.0.1 - from the file “Shake Reduction.8bf”
Shear 18.0.1 - from the file “Standard MultiPlugin.8bf”
Skewness 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
Smart Blur 18.0.1 - from the file “Standard MultiPlugin.8bf”
Smudge Stick 18.0.1 - from the file “Filter Gallery.8bf”
Solarize 18.0.1 (2017.0.1 x001 x003) - from the file “Solarize.8bf”
Spaces 18.0.1 - from the file “Spaces.8li”
Spatter 18.0.1 - from the file “Filter Gallery.8bf”
Spherize 18.0.1 - from the file “Standard MultiPlugin.8bf”
Sponge 18.0.1 - from the file “Filter Gallery.8bf”
Sprayed Strokes 18.0.1 - from the file “Filter Gallery.8bf”
Stained Glass 18.0.1 - from the file “Filter Gallery.8bf”
Stamp 18.0.1 - from the file “Filter Gallery.8bf”
Standard Deviation 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
STL 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
Sumi-e 18.0.1 - from the file “Filter Gallery.8bf”
Summation 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
Targa 18.0.1 - from the file “Standard MultiPlugin.8bf”
Texturizer 18.0.1 - from the file “Filter Gallery.8bf”
Tiles 18.0.1 - from the file “Standard MultiPlugin.8bf”
Torn Edges 18.0.1 - from the file “Filter Gallery.8bf”
Twirl 18.0.1 - from the file “Standard MultiPlugin.8bf”
U3D 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
Underpainting 18.0.1 - from the file “Filter Gallery.8bf”
Vanishing Point 18.0.1 - from the file “VanishingPoint.8bf”
Variance 18.0.1 (2017.0.1 x001 x003) - from the file “statistics.8ba”
Virtual Reality Modeling Language | VRML 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
Water Paper 18.0.1 - from the file “Filter Gallery.8bf”
Watercolor 18.0.1 - from the file “Filter Gallery.8bf”
Wave 18.0.1 - from the file “Standard MultiPlugin.8bf”
Wavefront|OBJ 18.0.1 (2017.0.1 x001 x003) - from the file “U3D.8bi”
WIA Support 18.0.1 (2017.0.1 x001 x003) - from the file “WIASupport.8li”
Wind 18.0.1 - from the file “Standard MultiPlugin.8bf”
Wireless Bitmap 18.0.1 (2017.0.1 x001 x003) - from the file “WBMP.8bi”
ZigZag 18.0.1 - from the file “Standard MultiPlugin.8bf”
Optional and third party plug-ins: NONE
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
com.adobe.inapp.purchase 2.7.122 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\purchase.html”
Recent Files 1.4.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.ccx.start\index.html”
Libraries 2.7.122 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.DesignLibraryPanel.html\index.html”
New Document 1.4.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.ccx.start\fnft.html”
Start 1.4.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.ccx.start\index.html”
com.adobe.experimentation.extension 2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.experimentation.extension\index.html”
Adobe Color Themes 6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
Export As 3.0.8 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2017\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
Device Preview 1.3.1 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSPanel\panel.html”
com.adobe.preview.loader 1.3.1 - from the file “C:\Program Files\Common Files\Adobe\CEP\extensions\com.adobe.previewHD\PSLoader\loader.html”
Installed TWAIN devices: NONE
Other:
Number of Launches: 6
Version: 7 SP1
System architecture: Intel CPU Family:6, Model:12, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2, HyperThreading
Physical processor count: 2
Logical processor count: 4
Built-in memory: 8116 MB
Free memory: 4504 MB
Memory available to Photoshop: 6870 MB
Touch Bar: Enabled.
Highbeam: Enabled.
Image tile size: 128K
TextComposer: Latin
Display: 1
Display Bounds: top=0, left=0, bottom=1080, right=1920
Display: 2
Display Bounds: top=0, left=1920, bottom=1080, right=3840
Display: 3
Display Bounds: top=-1080, left=2134, bottom=0, right=4054
Display: 4
Display Bounds: top=-1080, left=214, bottom=0, right=2134
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=2
NumCLGPUs=2
NumNativeGPUs=0
glgpu[0].GLVersion="4.0"
glgpu[0].IsIntegratedGLGPU=1
glgpu[0].GLMemoryMB=2112
glgpu[0].GLName="Intel(R) HD Graphics 4600"
glgpu[0].GLVendor="Intel"
glgpu[0].GLVendorID=32902
glgpu[0].GLDriverVersion="9.18.10.3204"
glgpu[0].GLRectTextureSize=8192
glgpu[0].GLRenderer="Intel(R) HD Graphics 4600"
glgpu[0].GLRendererID=1042
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igdumdim32,igd10iumd32,igd10iumd32"
glgpu[0].GLDriverDate="20130603000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.30 - Build 9.18.10.3204"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1447]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[80]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[64]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=0
clgpu[0].CLPlatformVersion="1.2 "
clgpu[0].CLDeviceVersion="1.2 "
clgpu[0].IsIntegratedCLGPU=1
clgpu[0].CLMemoryMB=1624
clgpu[0].CLName="Intel(R) HD Graphics 4600"
clgpu[0].CLVendor="Intel(R) Corporation"
clgpu[0].CLVendorID=32902
clgpu[0].CLDriverVersion="9.18.10.3204"
clgpu[0].CLBandwidth=9.01342e+09
clgpu[0].CLCompute=80.7833
glgpu[1].GLVersion="4.0"
glgpu[1].IsIntegratedGLGPU=0
glgpu[1].GLMemoryMB=1024
glgpu[1].GLName="AMD Radeon HD 5450"
glgpu[1].GLVendor="Intel"
glgpu[1].GLVendorID=4098
glgpu[1].GLDriverVersion="15.200.1062.1004"
glgpu[1].GLRectTextureSize=8192
glgpu[1].GLRenderer="Intel(R) HD Graphics 4600"
glgpu[1].GLRendererID=26873
glgpu[1].HasGLNPOTSupport=1
glgpu[1].GLDriver="aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.dll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll"
glgpu[1].GLDriverDate="20150803000000.000000-000"
glgpu[1].CanCompileProgramGLSL=1
glgpu[1].GLFrameBufferOK=1
glgpu[1].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.30 - Build 9.18.10.3204"
glgpu[1].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1447]
glgpu[1].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
glgpu[1].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[80]
glgpu[1].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[1].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[16]
glgpu[1].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[1].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[1].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[1].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[64]
glgpu[1].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[1].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[1].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[1].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[1].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[1].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[1].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[1].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=0
clgpu[1].CLPlatformVersion="2.0 AMD-APP (1800.8)"
clgpu[1].CLDeviceVersion="1.2 AMD-APP (1800.8)"
clgpu[1].IsIntegratedCLGPU=0
clgpu[1].CLMemoryMB=1024
clgpu[1].CLName="Cedar"
clgpu[1].CLVendor="Advanced Micro Devices, Inc."
clgpu[1].CLVendorID=4098
clgpu[1].CLDriverVersion="1800.8 (VM)"
clgpu[1].CLBandwidth=6.57828e+09
clgpu[1].CLCompute=9.49095
Serial number: 91190345617621732021
GUIDBucket:
bucket: 0
test: control
Temporary file path: C:\Users\ankek\AppData\Local\Temp\
Scratch volume(s):
Startup, 918.2G, 854.7G free
Required plug-ins:
3D Studio 18.0.1 (2017.0.1 x001 x003) - from the file “U3D”
Accented Edges 18.0.1 - from the file “Filter Gallery”
Adaptive Wide Angle 18.0.1 - from the file “Adaptive Wide Angle”
Angled Strokes 18.0.1 - from the file “Filter Gallery”
Average 18.0.1 (2017.0.1 x001 x003) - from the file “Average”
Bas Relief 18.0.1 - from the file “Filter Gallery”
BMP 18.0.1 - from the file “Standard MultiPlugin”
Camera Raw 9.8 - from the file “Camera Raw”
Camera Raw Filter 9.8 - from the file “Camera Raw”
Chalk && Charcoal 18.0.1 - from the file “Filter Gallery”
Chrome 18.0.1 - from the file “Filter Gallery”
Cineon 18.0.1 (2017.0.1 x001 x003) - from the file “Cineon”
Clouds 18.0.1 (2017.0.1 x001 x003) - from the file “Clouds”
Collada 18.0.1 (2017.0.1 x001 x003) - from the file “U3D”
Color Halftone 18.0.1 - from the file “Standard MultiPlugin”
Colored Pencil 18.0.1 - from the file “Filter Gallery”
CompuServe GIF 18.0.1 - from the file “Standard MultiPlugin”
Conté Crayon 18.0.1 - from the file “Filter Gallery”
Craquelure 18.0.1 - from the file “Filter Gallery”
Crop and Straighten Photos 18.0.1 (2017.0.1 x001 x003) - from the file “CropPhotosAuto”
Crop and Straighten Photos Filter 18.0.1 - from the file “Standard MultiPlugin”
Crosshatch 18.0.1 - from the file “Filter Gallery”
Crystallize 18.0.1 - from the file “Standard MultiPlugin”
Cutout 18.0.1 - from the file “Filter Gallery”
Dark Strokes 18.0.1 - from the file “Filter Gallery”
De-Interlace 18.0.1 - from the file “Standard MultiPlugin”
Dicom 18.0.1 - from the file “Dicom”
Difference Clouds 18.0.1 (2017.0.1 x001 x003) - from the file “Clouds”
Diffuse Glow 18.0.1 - from the file “Filter Gallery”
Displace 18.0.1 - from the file “Standard MultiPlugin”
Dry Brush 18.0.1 - from the file “Filter Gallery”
Eazel Acquire 18.0.1 (2017.0.1 x001 x003) - from the file “EazelAcquire”
Entropy 18.0.1 (2017.0.1 x001 x003) - from the file “statistics”
Export Color Lookup Tables NO VERSION - from the file “Export3DLUT”
Extrude 18.0.1 - from the file “Standard MultiPlugin”
FastCore Routines 18.0.1 (2017.0.1 x001 x003) - from the file “FastCore”
Fibers 18.0.1 - from the file “Standard MultiPlugin”
Film Grain 18.0.1 - from the file “Filter Gallery”
Filter Gallery 18.0.1 - from the file “Filter Gallery”
Flash 3D 18.0.1 (2017.0.1 x001 x003) - from the file “U3D”
Fresco 18.0.1 - from the file “Filter Gallery”
Glass 18.0.1 - from the file “Filter Gallery”
Glowing Edges 18.0.1 - from the file “Filter Gallery”
Google Earth 4 18.0.1 (2017.0.1 x001 x003) - from the file “U3D”
Graphic Pen 18.0.1 - from the file “Filter Gallery”
Halftone Pattern 18.0.1 - from the file “Filter Gallery”
HDRMergeUI 18.0.1 - from the file “HDRMergeUI”
HSB/HSL 18.0.1 - from the file “Standard MultiPlugin”
IFF Format 18.0.1 - from the file “Standard MultiPlugin”
IGES 18.0.1 (2017.0.1 x001 x003) - from the file “U3D”
Ink Outlines 18.0.1 - from the file “Filter Gallery”
JPEG 2000 18.0.1 - from the file “JPEG2000”
Kurtosis 18.0.1 (2017.0.1 x001 x003) - from the file “statistics”
Lens Blur 18.0.1 - from the file “Lens Blur”
Lens Correction 18.0.1 - from the file “Lens Correction”
Lens Flare 18.0.1 - from the file “Standard MultiPlugin”
Liquify 18.0.1 - from the file “Liquify”
Matlab Operation 18.0.1 (2017.0.1 x001 x003) - from the file “ChannelPort”
Maximum 18.0.1 (2017.0.1 x001 x003) - from the file “statistics”
Mean 18.0.1 (2017.0.1 x001 x003) - from the file “statistics”
Median 18.0.1 (2017.0.1 x001 x003) - from the file “statistics”
Mezzotint 18.0.1 - from the file “Standard MultiPlugin”
Minimum 18.0.1 (2017.0.1 x001 x003) - from the file “statistics”
MMXCore Routines 18.0.1 (2017.0.1 x001 x003) - from the file “MMXCore”
Mosaic Tiles 18.0.1 - from the file “Filter Gallery”
Multiprocessor Support 18.0.1 (2017.0.1 x001 x003) - from the file “MultiProcessor Support”
Neon Glow 18.0.1 - from the file “Filter Gallery”
Note Paper 18.0.1 - from the file “Filter Gallery”
NTSC Colors 18.0.1 (2017.0.1 x001 x003) - from the file “NTSC Colors”
Ocean Ripple 18.0.1 - from the file “Filter Gallery”
OpenEXR 18.0.1 - from the file “Standard MultiPlugin”
Paint Daubs 18.0.1 - from the file “Filter Gallery”
Palette Knife 18.0.1 - from the file “Filter Gallery”
Patchwork 18.0.1 - from the file “Filter Gallery”
Paths to Illustrator 18.0.1 - from the file “Standard MultiPlugin”
PCX 18.0.1 (2017.0.1 x001 x003) - from the file “PCX”
Photocopy 18.0.1 - from the file “Filter Gallery”
Photoshop 3D Engine 18.0.1 (2017.0.1 x001 x003) - from the file “Photoshop3DEngine”
Photoshop Touch 14.0 - from the file “PSDX”
Picture Package Filter 18.0.1 (2017.0.1 x001 x003) - from the file “ChannelPort”
Pinch 18.0.1 - from the file “Standard MultiPlugin”
Pixar 18.0.1 (2017.0.1 x001 x003) - from the file “Pixar”
Plaster 18.0.1 - from the file “Filter Gallery”
Plastic Wrap 18.0.1 - from the file “Filter Gallery”
PLY 18.0.1 (2017.0.1 x001 x003) - from the file “U3D”
PNG 18.0.1 - from the file “Standard MultiPlugin”
Pointillize 18.0.1 - from the file “Standard MultiPlugin”
Polar Coordinates 18.0.1 - from the file “Standard MultiPlugin”
Portable Bit Map 18.0.1 (2017.0.1 x001 x003) - from the file “PBM”
Poster Edges 18.0.1 - from the file “Filter Gallery”
PRC 18.0.1 (2017.0.1 x001 x003) - from the file “U3D”
Radial Blur 18.0.1 - from the file “Standard MultiPlugin”
Radiance 18.0.1 (2017.0.1 x001 x003) - from the file “Radiance”
Range 18.0.1 (2017.0.1 x001 x003) - from the file “statistics”
Render Color Lookup Grid NO VERSION - from the file “Export3DLUT”
Reticulation 18.0.1 - from the file “Filter Gallery”
Ripple 18.0.1 - from the file “Standard MultiPlugin”
Rough Pastels 18.0.1 - from the file “Filter Gallery”
Save for Web 18.0.1 - from the file “Save for Web”
ScriptingSupport 18.0.1 - from the file “ScriptingSupport”
Shake Reduction 18.0.1 - from the file “Shake Reduction”
Shear 18.0.1 - from the file “Standard MultiPlugin”
Skewness 18.0.1 (2017.0.1 x001 x003) - from the file “statistics”
Smart Blur 18.0.1 - from the file “Standard MultiPlugin”
Smudge Stick 18.0.1 - from the file “Filter Gallery”
Solarize 18.0.1 (2017.0.1 x001 x003) - from the file “Solarize”
Spaces 18.0.1 - from the file “Spaces”
Spatter 18.0.1 - from the file “Filter Gallery”
Spherize 18.0.1 - from the file “Standard MultiPlugin”
Sponge 18.0.1 - from the file “Filter Gallery”
Sprayed Strokes 18.0.1 - from the file “Filter Gallery”
Stained Glass 18.0.1 - from the file “Filter Gallery”
Stamp 18.0.1 - from the file “Filter Gallery”
Standard Deviation 18.0.1 (2017.0.1 x001 x003) - from the file “statistics”
STL 18.0.1 (2017.0.1 x001 x003) - from the file “U3D”
Sumi-e 18.0.1 - from the file “Filter Gallery”
Summation 18.0.1 (2017.0.1 x001 x003) - from the file “statistics”
Targa 18.0.1 - from the file “Standard MultiPlugin”
Texturizer 18.0.1 - from the file “Filter Gallery”
Tiles 18.0.1 - from the file “Standard MultiPlugin”
Torn Edges 18.0.1 - from the file “Filter Gallery”
Twirl 18.0.1 - from the file “Standard MultiPlugin”
U3D 18.0.1 (2017.0.1 x001 x003) - from the file “U3D”
Underpainting 18.0.1 - from the file “Filter Gallery”
Vanishing Point 18.0.1 - from the file “VanishingPoint”
Variance 18.0.1 (2017.0.1 x001 x003) - from the file “statistics”
Virtual Reality Modeling Language | VRML 18.0.1 (2017.0.1 x001 x003) - from the file “U3D”
Water Paper 18.0.1 - from the file “Filter Gallery”
Watercolor 18.0.1 - from the file “Filter Gallery”
Wave 18.0.1 - from the file “Standard MultiPlugin”
Wavefront|OBJ 18.0.1 (2017.0.1 x001 x003) - from the file “U3D”
WIA Support 18.0.1 (2017.0.1 x001 x003) - from the file “WIASupport”
Wind 18.0.1 - from the file “Standard MultiPlugin”
Wireless Bitmap 18.0.1 (2017.0.1 x001 x003) - from the file “WBMP”
ZigZag 18.0.1 - from the file “Standard MultiPlugin”
Extensions:
Hi Shelley,
So here's what your GPU specs looks like:
The sniffer is not getting information from the AMD and Intel cards on your machine.
Other:
The 4600 is the onboard graphics. I'm thinking that is what her version of Photoshop is using.
You can check that for sure under Edit > Preferences > Performance > Graphics Processor.
The Intel is enough to run Photoshop. Wonder if that can be forced to Photoshop in the CCC?
20130603000000.000000-000 Her driver is old
Next is the Radeon. So perhaps the four monitors are connected the Radeon and not the Intel?
dated 20150803000000.000000-000
Anyway, this what I'm getting at first glance.
Gene
