Okay, looks like I have run into a new tech issue I did not know I had.
I am using CS6, and have for years, no issues. Have used various video camera's over the years.
We started to use our Galaxy S5 phones to start taking some video a few years ago. I integrated this and the video
from my Sony camera and never had an issue.
I just started to edit video for my last years christmas video and everything was going great until I hit March. Various
clips from the month would not conform correctly and kept giving me errors. But not all clips!
So as I looked more, a change that happened was in March we upgraded one phone from a galaxy S5 to a S7. The video
only from the S7 was having issues. When I look at video from each phone with mediainfo, I see really nothing that is different.
They are both variable frame rate. But the S5 works, while the S7 is flaky.
I have started to run the video through handbrake with the output being a constant frame rate, since this is what I am reading is the only fix?
The amount of work I have to do, if there is no other fix, is really really the pits. Now, if the S5 also was flaky I would say I am stuck, but
to have the S5's VFR work, but the S7's VFR fail, well, what is the difference?
I am assuming one cannot configure ones cell phone to always shoot in CFR so I can eliminate this issue?
So, am I stuck?
Wow, this really hurts.
Premiere Pro is not designed to work with VFR video, so I am surprised that you did not have problems with the earlier video
The only solution I know of is to convert to CFR so PPro may properly edit the video
This is what I do not understand either, which is why I keep asking why.
Am re-encoding clips now with handbrake and see what happens. So far the ones I have re-encoded are not seeming to be having issues again.
Sure cannot believe I cannot set my video on my phones to a CFR setting. This extra step is nuts, let alone all the rework I now have to do. Guess one learns new stuff each day. Another reason I am staying away from 4K stuff. I do not need anymore issues.
