4 Replies Latest reply on Feb 26, 2017 8:19 PM by georgew42995111
    Time lapse photography
    georgew42995111 Level 1
      I am trying out some time lapse photography, How do I link the photos into a film in lightroom 6.8.
      Is there a preset or App I need, if so where do I find it and how do I load it.
        • 1. Re: Time lapse photography
          Lightroom doesn't have that capability. You need a video editing program that has that feature. I have only briefly looked at how to do this using Adobe Premiere Pro, but haven't tried it yet.
          • 2. Re: Time lapse photography
            Jao vdL Adobe Community Professional & MVP
            You can't do it natively but there are plugins that will do it for you in Lightroom. One example is here: https://lrtimelapse.com/
            If you have Photoshop, it is much easier and will give better results doing it in there.
            • 3. Re: Time lapse photography
              Conrad C Adobe Community Professional & MVP
              If you want the simplest and cheapest solution, export your images to a folder cropped and sized to the video frame size you need (such as 1920 x 1080 pixels), and bring them into any video program that can process a folder of images into a single video clip. iMovie and Windows Movie Maker can do this, there are time lapse tutorials out there for those applications.
              Adobe Premiere and After Effects (and many other video applications) can import an entire folder of still images into a single video clip. If your original images are in raw format, you must export TIFF or JPEG versions of the images to use them as a still sequence in most video editors.
              After Effects can work with raw files directly. In After Effects, you can open the first raw frame within Camera Raw and it will update the rest of the frames in the clip. But this can be slow since entire raw files must be processed when you make edits.
              LRTimelapse is a great solution if you're going to be doing this a lot. It's not cheap, but it's tightly integrated into Lightroom and can process a folder of Lightroom images (including raw) straight to a time lapse clip without needing any video editing application. LRTimelapse makes it possible to use the Develop controls in Lightroom to animate corrections or effects, such as exposure or color temperature, so that they gradually change across any ranges of frames in the folder.
              • 4. Re: Time lapse photography
                Tried Prem Pro.  Not much help really.  Movie maker didn't really work that well either, even when I brought the full version. LRTimelapse is great, there is a free version, doesn't have all the full pro stuff.  It still does a great job and works well for those playing the learn.  Works well with Lightroom and works with RAW files.  Thanks for the help and advice guys.  P.S. watch the tutorial to get the best out of LRTimelapse.
