We have developed an Adobe AIR application that we point to the URL of our flash web application. We are seeing differences in the communication behavior of our web application with the Adobe AIR container verses Internet Explorer. We are seeing some communication drops fro the Adobe AIR container in our requests back to the web server for requests that take a longer time. Internet Explorer seems to be much more tolerant and handles much better.
Today I was debugging some processing on the web server. I observed that Internet Explorer would wait nicely for my debugging. When I attempted the same thing with the Adobe AIR Container, it fails in the communications.
As I missing some configuration of the Adobe AIR container?
Hmm I think you can set a timeout on the URLRequest, no?
The exact same flash code is running in both Internet Explorer and Adobe Air. So I don't think it is in the code and more flash environmental, unless of course there are different default behaviors.
I was on the mobile earlier, so I couldn't look this up and thought I'd just give you a direction. So let me google this for you:
Flash Player uses the browser to execute URL requests and uses the same timeouts as your browser. In Air you can use URLRequest.idleTimeout to specify your own timeout.
Perhaps this is a better description of the configuration I am using:
We have developed an application front end in Flash. Now we are allowing access either from a browser or an Adobe AIR application. We point to the URL of our web server and download swf components and data via a NetConnection. We are seeing differences in the communication behavior of our web application with the Adobe AIR container verses Internet Explorer. There are some communication drops between the Adobe AIR container in our requests back to the web server for requests that take a longer time. Internet Explorer seems to be much more tolerant and handles much better.
It is not an issue simply with the connection reliability because the same behaviors can be observed by setting and holding a breakpoint on the requests for data from the web server.
So, same code but different behaviors when flash runs in Adobe Air. We have made sure both are using the same version of the flash dll.
As I missing some configuration of the Adobe AIR container that changes default behaviors?
My last reply answered exactly this question. Did you read it?
Sorry but it does not. The idle timeout you mentioned is for a URLRequest. The communication that is "timing out" is the NetConnection.
Oh I missed that. Sorry, my bad.
I am looking at this link....AIR RemoteObject timeout in Windows - Is There A Solution???
Has this problem really been around for 7 YEARS?
