1 Reply Latest reply on Aug 26, 2008 11:57 PM by Ratsnackbar
    Remote Object external server  path
    nikos101 Level 2
      I'm rather new to this CF and remote objects stuff :(
      If I run a .swf on the server with a remote object source = "server_path.mycfc"
      what would source be if I was connecting to an external server at say www.mysite.com? Would it be
      mysite.com.server_path.mycfc?
        • 1. Re: Remote Object external server  path
          Ratsnackbar Level 2
          It is going to be the path to the cfc starting at the root of the site to the CFC unless there is a ColdFusion server mapping that overrides it. However I have not tried this using mappings and I hear from others it does not work well.
          So lets say you had a cfc that resided in this folder starting from the root of your site
          {siteRoot}/com/mydomain/cfcs/
          The source would be com.mydomain.cfcs
          And the destination would be ColdFusion (unless you had a need to configure a different destination in the XML files on the server.)
          So to answer your question more exactly a fully qualified domain name such as www.mysite.com simply points to the root of your site. The Source then states starting from the root where is the CFC I am wanting to talk to.
          Where it gets confusing is the habit of CF developers to place all their cfc's into folder paths using the Reverse domain name like the above {siteRoot}/com/mydomain/cfcs/.
          If you were to see this exact path in a server log however the way it might look would be
          http://www.mydomain.com/com/mydomain/cfcs/mycfc.cfc
          Of course you will never see that in a log because of the nature of cfc's but the point is to show how the path / source works.
          Hope that helps
