• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Compare documents from the command line
New Here ,
Feb 20, 2017 Feb 20, 2017
I would like to setup automatic comparison between documents in TortoiseSVN, but I would need some way to do it from the command line.
The TortoiseSVN settings window looks like this for other file types and I would need some way to specify to document paths and file to open them with. Does the FrameMaker.exe provide any command line parameters?
Views
334
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
Feb 21, 2017 Feb 21, 2017
It might make sense to use MIF instead of FM, as FM is a binary format and MIF is plain text.
In addition to that FrameMaker has a File Compare utility (File > Utilities > Compare Documents), which might be interesting for you to have a look at.
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
Thank you for the reply Stefan.
I just found out about MIF while googling for solutions and it looks like a nice file format. I will take some time to learn a bit more about it and see if we can save a few of our documents in it for testing purposes.
I do know about the menu item, but that means that I have to manually check out the old revision into a folder, open my working copy and the older revision and then select "File > Utilities > Compare Documents". It would be very handy if there was a command line interface like this:
Framemaker.exe /Compare %file1% %file%
which would open the files and execute the compare document function automatically.
Votes
Translate
Translate
Report
Report
