3 Replies Latest reply on Aug 28, 2008 1:55 PM by thephantom6969
    certificate
    thephantom6969 Level 1
      Is there any less expensive sources for a certificate (AIR) than Thawte?
        • 1. Re: certificate
          Level 7
          Adobe Newsbot hopes that the following resources helps you. NewsBot is experimental and any feedback (reply to this post) on its utility will be appreciated:
          Flex 3 - Digitally signing an AIR file:
          You can also export and sign AIR files using Flex Builder, Dreamweaver, and the AIR update for ... Example: Getting an AIR Developer Certificate from Thawte
          Link: http://livedocs.adobe.com/flex/3/html/distributing_apps_4.html
          thawte | RIA pedia - Rich Internet Applications - Its all about:
          Certify AIR Applications with Thawte. Wed, 2007-11-14 17:00 mikepotter ... 360 Flex in San Jose, CA, Aug 18 - 20, 2008; Adobe MAX in San Francisco,
          Link: http://www.riapedia.com/taxonomy/term/288/all
          Flex 3 - Export Release Build:
          Sign the application using a VeriSign or Thawte digital certificate ... If you have multiple projects and applications open in Flex Builder, select the AIR
          Link: http://livedocs.adobe.com/flex/3/html/build_5.html
          Thawte | Serge Jespers:
          If you get a code signing certificate from a company like Thawte.com and use that to ... Learn Flex in a week (or less) for free · Personalized Flash video
          Link: http://www.webkitchen.be/tag/thawte/
          Flex 3 - Managing projects:
          You can set the following project-specific preferences in Flex Builder: .... Sign the application using a VeriSign or Thawte digital certificate
          Link: http://livedocs.adobe.com/flex/3/html/projects_4.html
          Adobe - Developer Center : Digitally signing Adobe AIR applications:
          Signing your AIR applications with Flex Builder is a simple process. ... you acquired above from Thawte (or any registered certificate authority).
          Link: http://www.adobe.com/devnet/air/articles/signing_air_applications_03.html
          Disclaimer: This response is generated automatically by the Adobe NewsBot based on Adobe Community Engine.
          • 2. Re: certificate
            Dr. Fred Mbogo Level 1
            Last I looked, there were only three companies selling AIR-compatible code signing certs, the third being Comodo. There was uncertainty about whether using one of their certs would actually result in a green checkmark in the installer because they're not a top-level provider: they chain from Thawte, and it wasn't certain that the AIR installer would follow the cert chain up to someone it trusted.
            So, I got a Thawte cert and haven't looked at the issue since. If you decide to roll the dice, let us know how it comes out, okay? :)
            • 3. Re: certificate
              I took the published directory that AIR created and used Inno setup on it. In installed programs my company name appears, plus I have put a key in from Inno. The customer has to have AIR 1.1 installed. I still don't see what certifying does other than Thawte and VeriSign get richer for doing virtually nothing. What do you think?
