4 Replies Latest reply on Feb 22, 2017 10:13 PM by ratna_282017
    gotoandStop within a movie clip
    ratna_282017 Level 1
      I have a movie clip name shoes_mc, within this movie clip, there are 10 layers with increasing number of pair of shoes (1 pair in the 1st layer, 2 pairs in the 2nd, and so on). I also have a button name plus_btn, I apply the code below, so every time I click the button, it would gotoandstop to next layer within shoes_mc. I used trace("works") to se if the code works or not.
      Then I tested the movie and the trace showed "works" but the layer didn't go to the next layer. It stayed in the 1st layer.
      In addition, actually I'm looking for a way to make a plus minus button, every time I click plus, 1 pair of shoes appear, and every time I click minus, 1 pair of shoes disappear. But I don't get logic about this, and I thought the gotoanstop within movie clip will works. Please help me.
      plus_btn.onRelease=function()
      shoes_mc.nextFrame();
      trace("works");
        • 1. Re: gotoandStop within a movie clip
          Colin Holgate MVP & Adobe Community Professional
          You used the word 'layer' a few times when I hope you meant 'frame'. shoes_mc should have 10 frames, with 1 pair of shoes in frame 1, 2 pairs in frame 2, and so on.
          If that is how you have it, then your script will work, other than the fact the movieclip will play in a loop until the first time you click the button.
          Here's a script that stops the shoes_mc at the beginning, and also has the code for a minus_btn that you will need to make:
          shoes_mc.stop();
          plus_btn.onRelease = function()
            trace("works");
          minus_btn.onRelease = function()
            shoes_mc.prevFrame();
            trace("works");
          • 2. Re: gotoandStop within a movie clip
            oh yeah, I meant frame not layer. Thanks for your correction and so much thanks for your help. The code works really well
            • 3. Re: gotoandStop within a movie clip
              Glad to hear it!
              • 4. Re: gotoandStop within a movie clip
                Hello I'm back, is it okay to ask here or I should post a new thread?
                I have a button, check_btn, I want to check if the number of shoes has reached a certain number. So I think to use this:
                shoes_mc.stop();
                plus_btn.onPress = function()
                  trace("works1");
                  trace("works2");
                check_btn.onPress = function()
                if (shoes_mc.currentFrame == 11)
                  trace("OK FULL");
                else
                trace("NOT YET");
                The problem is, eventhough I have reached the 11th rame, the trace of check_btn still show NOT YET. I'm thinking about using a var, so I changed the code like this:
                shoes_mc.stop();
                var fullshoes:Boolean = false;
                  trace("works1");
                     if(currentFrame == 11)
                          fullshoes = true:
                  trace("works2");
                if (fullshoes == true)
                  trace("OK FULL");
                else
                trace("NOT YET");
                But, it's still not working. Which part am I doing wrong? and why? Thank you in advance.
