Cuando abro la Galeria de Filtros, algunos de ellos estan en gris (por ejemplo Efectos de iluminacion) y no me permite usarlos cuando podia usarlos con versiones anteriores. Estoy usando version 2017. Como puedo resolverlo?
Filter Gallery and Render -Lighting effects both work only on 8 bit images - if you have a 16 bit image both will be grayed out.
Lighting effects also requires a supported graphics card and "Use Graphics Processor" to be enabled in Preferences -Performance
I hope that helps you
Dave
canizung0515 wrote
When I open the filters Gallery, some of them are in grey (for example lighting effects) and not allow me to use them when I could use with previous versions. I'm using version 2017. How do I resolve it?
What is the bit depth of the image?
What Image Mode is it?
If you are in 8bit RGB, are the options all there?
Hi canizung,
Please refer to the below article and make sure that your GPU is supported by the latest version of Photoshop.
Photoshop graphics processor (GPU) card FAQ
Regards,
Sahil
Dave
Ok. that's right. I did and solve. Thank you
Additionaly, my images was RGB 8 bits
