5 Replies Latest reply on Feb 25, 2017 3:11 PM by Szalam
    Import Premiere timeline Markers into AE??
    alphanine Level 1
      Hello,
      is there an easy way to export Premiere Pro Timeline markers to Ae?
      Premiere can export Markers to .CSV, .TXT & .HTML, the .TXT is not working, sp that leaves us with the .CSV & .HTML, but how can i use this information to convert them to markers in AE?
        • 1. Re: Import Premiere timeline Markers into AE??
          You can't. Unfortunately this stuff isn't compatible with each other.
          Mylenium
          • 2. Re: Import Premiere timeline Markers into AE??
            What?!? Mylenium is usually right, so I think he must have misunderstood the question.
            You can totally bring markers from Premiere to After Effects!
            And you don't even have to export anything.
            In AE, go to File>Import>Import Premiere Pro Project
            Pick your Premiere Project. (Choose all sequences or whatever - it shouldn't matter.)
            If you've left markers on footage, audio, or really any assets on a track in Premiere, you will have markers on the respective layers in AE.
            And, if you've got markers on your sequence in Premiere, they will show up as composition markers in AE.
            Both of them work and work well.
            • 3. Re: Import Premiere timeline Markers into AE??
              Sorry, I said "import" too many times.
              File>Import>Adobe Premiere Pro Project is the actual command.
              I forgot to mention, if you have marker names, comments, and duration on your timeline markers in Premiere, ALL OF THAT comes through in the composition markers in AE too.
              • 4. Re: Import Premiere timeline Markers into AE??
                alphanine Level 1
                Thanks, @Szalam, but this is not what am looking for, this solution is good for a local work between two apps, but I was wanted a solution for a remote editing machine that can send me Premiere's Timeline markers, to use them via expressions in AE.
                We are already using the method you mentioned, asking the editor to clear all the footage from the timeline and the project and to keep only one adjustment layer holding the markers on it, and then send us this project, but i was looking for an easier way to do this from marker panel, or File > Export > Markers.
                • 5. Re: Import Premiere timeline Markers into AE??
                  Well, then Mylenium did understand your question after all!
