1 Reply Latest reply on Aug 29, 2008 2:10 AM by Newsgroup_User
    timestamp error in AIR
    san00001 Level 1
      I am creating an AIR application with flex sdk.But i am getting timestamp not found error.hw to solve this issue
      adt -package -storetype pkcs12 -keystore sampleCert.pfx HelloWorld.air
      HelloWorld-app.xml HelloWorld.swf
      I cmd promp i am entering the above
      pls help me
        • 1. Re: timestamp error in AIR
          Level 7
          Adobe Newsbot hopes that the following resources helps you. NewsBot is experimental and any feedback (reply to this post) on its utility will be appreciated:
          Flex 3 - Backward compatibility:
          The configuration file syntax is also different between SDK 2.0.1 and SDK 3. If you use a customized flex-config.xml file, you must ensure that you match
          Link: http://livedocs.adobe.com/flex/3/html/versioning_4.html
          [#SDK-14896] Compilation error if Flex is in a path with:
          Mar 7, 2008 ... Copy flex SDK into a path that has '#', for example: c:\flex#3 2. Create the following test file: <?xml version='1.0' encoding='utf-8'?
          Link: http://bugs.adobe.com/jira/browse/SDK-14896
          Flex 3 - Configuring the web-tier compiler:
          If you are currently using the SDK and have a custom flex-config.xml file, ... that are shown in the browser when the compiler returns an error warning.
          Link: http://livedocs.adobe.com/flex/3/html/apache_4.html
          [#SDK-15139] Flex Compiler Oem doesn't support swf resource-bundle:
          Milestone: SDK Flex 3.1.0. Affected OS(s): All OS Platforms - All. Steps to Reproduce:. Hide. I tried to compile sample FlightReservation2 with Flex
          Link: https://bugs.adobe.com/jira/browse/SDK-15139
          [#SDK-782] Error when generating asdoc on an mxml file that:
          When using asdoc -doc sources {path}, where the {path} have an mxml file that loads a separate AS source script, an error is thrown Sample mxml file: <?xml
          Link: http://bugs.adobe.com/jira/browse/SDK-782
          Disclaimer: This response is generated automatically by the Adobe NewsBot based on Adobe Community Engine.
