• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Gradient in linked .ai file not displaying correctly in Indesign
Participant ,
Feb 22, 2017 Feb 22, 2017
I've linked an .ai file to my Indesign document. The Illustrator file has a gradient in it and displays correctly, like this:
However, in Indesign it appears like this:
How can I fix this so it displays correctly? Thanks.
Views
1.6K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert , Feb 23, 2017 Feb 23, 2017
Yes, very strange. I am running out of guesses. What happens when you make a new similar Illy file with freshly built gradient and put it into a new Indy file? And put it now also into the same old Indy file?
BTW, is every app patched up to date?
Votes
Translate
Translate
Community Expert ,
Have you checked to ensure the color model of the ai and indd file are the same? Are you running the document at High Quality in preferences (or by right-clicking the graphic and choosing High Quality Display)? Are you avoiding EPS files in favor of native .AI or .PDF files for placement into InDesign?
Mike Witherell
Votes
Translate
Translate
Report
Report
Participant ,
By colour model, do you mean RGB or CMYK? If so, they're both in RGB.
The screengrab was taken in high quality mode. I did mention that the file is an .ai.
Votes
Translate
Translate
Report
Report
Community Expert ,
Do you have Overprint Preview off or on?
Mike Witherell
Votes
Translate
Translate
Report
Report
Participant ,
It's off. Nothing ticked in the Attributes palette either.
The gradient was just built by using the gradient palette - dragging a purple swatch to the black slider and a blue swatch to the white slider. Then I saved the new gradient swatch and applied it to my various shapes, some with the gradient rotated and some shapes then made semi transparent.
Votes
Translate
Translate
Report
Report
Community Expert ,
In the Illustrator file, how exactly are you building the gradient? Is anything set to Overprint in the Attributes panel of Illy?
Mike Witherell
Votes
Translate
Translate
Report
Report
Community Expert ,
What happens if you remove the semi-transparency?
Mike Witherell
Votes
Translate
Translate
Report
Report
Participant ,
Nothing, it doesn't make any difference... Interestingly an exported PDF behaves the same, but an exported png behaves correctly. And the thumbnail preview within Finder on my desktop also displays incorrectly.
Votes
Translate
Translate
Report
Report
Community Expert ,
That only leaves Export to IDML as a comparison test. I would re-save-as the .AI file, just for good measure.
Mike Witherell
Votes
Translate
Translate
Report
Report
Participant ,
presumably you mean exporting my main indesign file?
OK, have tried that - no difference.
crazy right?
Votes
Translate
Translate
Report
Report
Community Expert ,
Mike Witherell
Votes
Translate
Translate
Report
Report
Participant ,
LATEST
I don't believe this - I created the file in the exact same way from scratch, and it's fine!
Votes
Translate
Translate
Report
Report
