9 Replies Latest reply on Aug 27, 2008 10:44 AM by Newsgroup_User
    CuePoint help
    necie
      I have a progresive flv with an instance name of myVid which is already on the stage and set to autoplay via the component parameters tab. When the video plays and gets to a cue point I want the flv to pause. The cue point names (embedded when I used Flash Video Encoder) are cp01, cp02, and cp03. The video doens't stop on the specified cue point and instead just keeps playing. Can anyone help me with my code? Is there a better way to do it? Here is what I have so far:
        • 1. Re: CuePoint help
          Level 7
          necie,
          > to pause. Can anyone help me with my code?
          Sure thing.
          > var listener:Object = new Object();
          > listener.cuePoint = function(eventObject:Object):Void
          > if (eventObject.info.name == "cp1")
          So far, so good. You're checking for the cue point name as it was
          supplied by you.
          > myVid.gotoAndStop("cp1");
          Here's a significant problem. When you're dealing with video, you're
          either dealng with the NetConnection and NetStream classes, or you're
          dealing with the FLVPlayback class. Since you mentioned components, I'm
          guessing you're using FLVPlayback.
          It helps to understand that everything in ActionScript can be described
          in terms of an object. In this case, you're dealing with an FLVPlayback
          object. Objects are defined by their (usually namesake) classes. Think of
          a class as a recipe. Movie clips are defined by the MovieClip class; text
          fields by the TextField class; sounds by the Sound class, and so on. If
          you're formatting text, you'll want the TextFormat class, and so on. You
          get the idea.
          Classes generally describe one or more of the following three
          categories: properties (characteristics of the object), methods (things the
          object can do), and events (things the objectg can react to). You're using
          gotoAndStop(), which is an active term, basically a "verb." That means
          you're describing what the object can do ... in other words, a method. If
          you look up the FLVPlayback class, you'll find that the Methods heading does
          not contain a gotoAndPlay() method. That's a MovieClip method, which means
          it's something you can only instruct a movie clip to do.
          You will find a pause() method, though, and that's your ticket here. :)
          Obviously, when the video pauses, the cue points will stop, because they
          depend on the video actually rolling. So somewhere, you'll need to provide
          a mechanism for playing the video again. Maybe a button?
          David Stiller
          Co-author, Foundation Flash CS3 for Designers
          http://tinyurl.com/2k29mj
          "Luck is the residue of good design."
          • 2. Re: CuePoint help
            necie Level 1
            Sorry, I thought I was in the Actionscript 1 & 2 forum. I moved this question to that forum.
            • 3. Re: CuePoint help
              necie Level 1
              Wow, I'm reading your blog right now about FLV cue points. I get an email from the adobe forum and it's you with some info to help me out. You are an incredible educator. I used the NetStream instead of FLVPlayback. I used your code from your blog and tweaked it for my files and I added the pause(). It worked great. Now to get to that play button. I need to add a keyboard event. The desired result is the end user can continue to play the video by pressing the right arrow button. I'm trying to NOT use buttons. Here's what I have so far and the playing of the netStream isn't working.
              var nc:NetConnection = new NetConnection();
              nc.connect(null);
              var ns:NetStream = new NetStream(nc);
              videoPlayer.attachNetStream(ns);
              listener.onMetaData = function(evt:Object):void {};
              listener.onCuePoint = function(evt:Object):void {
              ns.pause();
              ns.client = listener;
              ns.play("CPVideo.flv");
              stage.addEventListener(KeyboardEvent.KEY_DOWN, playVideo);
              function playVideo(event:KeyboardEvent):void
              trace(event.keyCode);
              ns.play();
              • 4. Re: CuePoint help
                necie Level 1
                nc.connect(null);
                ns.pause();
                ns.play();
                • 5. Re: CuePoint help
                  Level 7
                  necie,
                  Heh, it's pretty neat when it works out that way.
                  Thanks, necie!
                  Keyboard makes good sense; just keep in mind, the SWF won't respond to
                  keyboard input (I think!) unless the SWF has focus. Test that to make sure.
                  > isn't working.
                  > ns.play();
                  The structure of your code is fine, but that play() method is the
                  culprit here. It needs at least one parameter, which tells the NetStream
                  instance what file to play. Without that parameter -- as you've seen --
                  Flash doesn't know what you're asking for.
                  The solution is to use the optional Boolean parameter of the pause()
                  method. In your cue point handler, use ns.pause(true); ... then, in your
                  keyboard handler, use ns.pause(false); -- that should do it!
                  David Stiller
                  Contributor, How to Cheat in Flash CS3
                  http://tinyurl.com/2cp6na
                  • 6. CuePoint help
                    necie Level 1
                    First of all please allow me to say thanks for helping me out. I've switched the code using your suggestions but am getting errors on the ns.pause(true); and the ns.pause(flase); methods. Here is what I have:
                    nc.connect(null);
                    ns.pause(true);
                    ns.pause(false);
                    • 7. Re: CuePoint help
                      Level 7
                      necie,
                      Sure thing.
                      I see why, too -- and I should have taken better care with my previous
                      reply! When you mentioned, in a previous post, you thought you were in the
                      Actionscript 1 & 2 forum, I got it stuck in my head that you were using AS2,
                      so my code suggestion was for the AS2 version of the NetStream class.
                      The fact that your stage reference is lowercase (AS3), and that your
                      keystroke event handlers use the KeyboardEvent class (AS3), should have
                      reminded me that you're actually using ActionScript 3.0.
                      So ... the Boolean parameter no longer applies. For AS3, use pause() --
                      no true/false parameter -- to pause your NetStream instance. Use
                      resume() -- again, no parameter -- to resume it.
                      David Stiller
                      Co-author, ActionScript 3.0: The Quick Answer Guide for Flash Professionals
                      http://tinyurl.com/2s28a5
                      • 8. Re: CuePoint help
                        necie Level 1
                        That worked just fine. Finally have a working video with cue point and keyboard control. Kinda feel like Tom Hanks in Cast Away after he makes fire. Thanks so much for your help. And thanks for explaining the details so well.
                        Perhaps one more question. I used the trace(event.keyCode); so that when I hit a key I could tell what number to use in the code. But where, and with what special syntax might I put these numbers. The space bar (39) will ns.pause(); at any time, while the cue points are predetermined pauses. The right arrow (32) will ns.resume(); the video. this is where I thought it would go, but it's not working:
                        stage.addEventListener(KeyboardEvent.KEY_DOWN, <32>, playVideo);
                        Am I on the right track?
                        • 9. Re: CuePoint help
                          Level 7
                          necie,
                          Ha, that's a great image! Sometimes I feel like he did when he had to
                          knock out his tooth with the ice skates.
                          You'll do that inside the event handler (your playVideo() function), and
                          when you see how, it'll make perfect sense.
                          Wrong track. ;) But check it out:
                          function playVideo(event:KeyboardEvent):void {
                          if (event.keyCode == 32) {
                          // do the space bar thing
                          if (event.keyCode == whatever) {
                          // do the whatever thing
                          As an alternative to using a series of if() statements, you could use a
                          switch() statement:
                          switch (event.keyCode == 32) {
                          case 32:
                          break;
                          case whatever:
                          break;
                          case whatever2:
                          // do the whatever2 thing
                          break;
                          David Stiller
