I have the latest update of Animate CC 2017.2 on PC using Windows 7 enterprise sp1 64bit. When I launch Animate, at the point when the launch window says "Loading Document Templates", it crashes(but it still has running when I open task manager, the process has animate.exe ). I tried reinstalling and deleted all related files, but still get crashes. I uninstalled and reinstalled, still crashes. Any ideas? Thanks for any help.
If you still need help, I suggest getting in touch with Adobe Customer Care. Contact Customer Care They should be able to investigate this issue further.
Preran
reset your preferences -
http://helpx.adobe.com/flash/kb/re-create-preferences-flash-professional.html
or remove
Win:
C:\Users\<username>\AppData\Local\Adobe\Animate CC 2017\ and
C\Users\<username>\AppData\Roaming\Adobe\Animate\2017\
I reset the preferences and try to remove again and reinstall again, still, can't run the program.
could you double check that version of animate cc?
Yes, Still...
2017.1 is the latest release. there's not even a beta 2017.2.
Preran
