4 Replies Latest reply on Mar 4, 2017 12:07 PM by c.pfaffenbichler
    Batch replace smart layer with eps files
    johnb73378901
      Hi everyone, I am hoping someone can please help me as I have over 500+ files just for one type of product.
      Basically I have eps files in a folder which are different sizes, I need someway of making one image in photoshop for example a rear view of a car, I want to select an area where a script will open the folder of eps files and insert, resize to a certain height or width and then save as a jpg, then repeat next eps file.
      Where you see the 0 - 60 eventually, will be replaced with another eps file, the back of the car remain the same.
      Hopefully someone can please help as lost on how to do this with a few thousand products.
      Thanks John
        • 1. Re: Batch replace smart layer with eps files
          Your description read like a logic puzzle that has errors in it.
          • 2. Re: Batch replace smart layer with eps files
            c.pfaffenbichler Level 9
            Is the element currently a Smart Object?
            Do the eps differ in proportions?
            How is the maximum area for the eps’ in the receiving image defined?
            If you had included the pertinent Panel/s in the screenshot you might have made your point more clearly. (edited)
            • 3. Re: Batch replace smart layer with eps files
              johnb73378901 Level 1
              Hi c.pfaffenbichler thank you so much for your response.
              Hope this clears things up.
              1. I am setting up my own website selling vinyl graphics, all are eps files of different proportions.
              2. I want to overlay each of the eps file on top of an image that I select so that it appears like in the above picture, I would set the size of the area and position of where the eps file will be placed (not sure how) and then save the file at 1000px x 1000px in jpg
              3. This would then repeat the next eps file and save again etc.
              How would I achieve this without having to do each file manually.
              Trying to create pictures like this.WS-15945-01.jpgWS-15967-01.jpgWS-32402-02.jpg
              Thanks John
              • 4. Re: Batch replace smart layer with eps files
                If the SO resides in a Group with a Layer Mask that defines the target area the following may help, though I did not bother with scaling the jpgs – either start with a layered file in the correct dimensions or amend the Script yourself.
                // replace selected smart object, scale according to layer froup’s layer mask and save jpgs;
                // 2017, use it at your own risk;
                #target photoshop
                if (app.documents.length > 0) {
                var myDocument = app.activeDocument;
                var theName= myDocument.name.match(/(.*)\.[^\.]+$/)[1];
                var thePath = myDocument.path;
                var theLayer = myDocument.activeLayer;
                // jpg options;
                var jpegOptions = new JPEGSaveOptions();
                jpegOptions.quality = 9;
                jpegOptions.embedColorProfile = true;
                jpegOptions.matte = MatteType.NONE;
                // check if layer is smart object;
                if (theLayer.kind != "LayerKind.SMARTOBJECT") {alert ("selected layer is not a smart object")}
                else {
                // select files;
                if ($.os.search(/windows/i) != -1) {var theFiles = File.openDialog ("please select files", "*.psd;*.psb;*.tif;*.eps", true)}
                else {var theFiles = File.openDialog ("please select files", getFiles, true)};
                if (theFiles) {
                var originalRulerUnits = app.preferences.rulerUnits;
                app.preferences.rulerUnits = Units.PIXELS;
                // get target area;
                myDocument.activeLayer = theLayer.parent;
                loadLayerMaskSelection (myDocument, theLayer.parent, false);
                var theDim = myDocument.selection.bounds;
                myDocument.activeLayer = theLayer;
                myDocument.selection.deselect();
                // work through the array;
                for (var m = 0; m < theFiles.length; m++) {
                // replace smart object;
                theLayer = replaceContents (theFiles[m], theLayer);
                // scale;
                var theBounds = theLayer.bounds;
                var theHor = (theDim[2]-theDim[0])/(theBounds[2]-theBounds[0])*100;
                var theVer = (theDim[3]-theDim[1])/(theBounds[3]-theBounds[1])*100;
                $.writeln(theDim);
                $.writeln((theDim[2]-theDim[0])/(theDim[3]-theDim[1]) +"\n"+ (theBounds[2]-theBounds[0])/(theBounds[3]-theBounds[1])+"\n");
                if ((theDim[2]-theDim[0])/(theDim[3]-theDim[1]) < (theBounds[2]-theBounds[0])/(theBounds[3]-theBounds[1])) {var theFactor = theHor}
                else {var theFactor = theVer};
                theLayer.resize(theFactor, theFactor, AnchorPosition.MIDDLECENTER);
                //save jpg;
                var theNewName = theFiles[m].name.match(/(.*)\.[^\.]+$/)[1];
                myDocument.saveAs((new File(thePath+"/"+theName+"_"+theNewName+".jpg")),jpegOptions,true);
                // reset;
                app.preferences.rulerUnits = originalRulerUnits;
                ////// get psds, tifs and jpgs from files //////
                function getFiles (theFile) {
                if (theFile.name.match(/\.(psd|tif|psb|eps)$/i) != null || theFile.constructor.name == "Folder") {
                return true
                ////// replace contents //////
                function replaceContents (newFile, theSO) {
                app.activeDocument.activeLayer = theSO;
                var idplacedLayerReplaceContents = stringIDToTypeID( "placedLayerReplaceContents" );
                var desc3 = new ActionDescriptor();
                var idnull = charIDToTypeID( "null" );
                desc3.putPath( idnull, new File( newFile ) );
                var idPgNm = charIDToTypeID( "PgNm" );
                desc3.putInteger( idPgNm, 1 );
                executeAction( idplacedLayerReplaceContents, desc3, DialogModes.NO );
                return app.activeDocument.activeLayer
                ////// also adapted from xbytor’s stdlib //////
                function loadLayerMaskSelection (doc, layer, invert) {
                  var desc = new ActionDescriptor();
                  var cref = new ActionReference();
                  cref.putProperty(charIDToTypeID("Chnl"), charIDToTypeID("fsel"));
                  desc.putReference(charIDToTypeID("null"), cref);
                  var tref = new ActionReference(); // Channel Kind ("Trsp" or "Msk ")
                  tref.putEnumerated(charIDToTypeID("Chnl"), charIDToTypeID("Chnl"), charIDToTypeID("Msk "));
                  desc.putReference(charIDToTypeID("T   "), tref);
                  if (invert == true) {desc.putBoolean(charIDToTypeID("Invr"), true)};
                  executeAction(charIDToTypeID("setd"), desc, DialogModes.NO);
