6 Replies Latest reply on Feb 23, 2017 9:38 AM by luizg25199346
    Print Blooket Problem. What I do?
    luizg25199346
      Hi. Many times I do a print blooket at Indesign, it appears this thin lines at images.
      I've tried many configurations from PDF conversions and I can't resolve.
      Could someone help me?
      Thanks.
      Gustavo
        • 1. Re: Print Blooket Problem. What I do?
          BobLevine MVP & Adobe Community Professional
          Looks like stitching artifacts from flattening. Try exporting a proper PDF and using the booklet function built into Acrobat to print it.
          • 2. Re: Print Blooket Problem. What I do?
            luizg25199346 Level 1
            BobLevine, I export using Adobe PDF Converter, from Acrobat DC.
            Please, see my print summary, if I doing something wrong, I can't see.
            Print Preset: [Custom]
            Printer: Adobe PDF Converter
            PPD: Adobe PDF
            PPD File: C:\WINDOWS\system32\spool\DRIVERS\x64\3\ADPDF9.PPD
            General
                Copies: 1
                Collate: N/A
                Reverse Order: Off
                Pages: All
                Sequence: N/A
                Spreads: N/A
                Print Master Pages: N/A
                Print Layers: Visible & Printable Layers
                Print Non-printing Objects: Off
                Print Blank Pages: On
                Print Visible Guides and Baseline Grids: Off
            Setup
                Paper Size: Custom
                Paper Width: Auto
                Paper Height: Auto
                Page Orientation: Portrait
                Paper Offset: 0 mm
                Paper Gap: 0 mm
                Transverse: Off
                Scaling: 100%
                Constrain Proportions: On
                Page Position: Centered
                Thumbnails: N/A
                Tiling: N/A
            Marks and Bleed
                Crop Marks: Off
                Bleed Marks: Off
                Registration Marks: Off
                Color Bars: Off
                Page Information: Off
                Printer Mark Type: Default
                Crop Mark Weight: 0.25 pt
                Mark Offset from Page: 2,117 mm
                Use Document Bleed Settings: Off
                Bleed Top: 2 mm
                Bleed Bottom: 2 mm
                Bleed Inside: 2 mm
                Bleed Outside: 2 mm
                Include Slug Area: N/A
            Output
                Color: Composite CMYK
                Text As Black: Off
                Trapping: N/A
                Flip: None
                Negative: N/A
                Screening: Default
                Simulate Overprint: N/A
            Graphics
                Send Data: All
                Download: Complete
                Download PPD Fonts: On
                PostScript®: Level 3
                Data Format: ASCII
            Color Management
                Document Profile: U.S. Web Coated (SWOP) v2
                Color Handling: Let PostScript® Printer Determine Colors
                Printer Profile: N/A
                Preserve CMYK Numbers: On
                Proof Profile: N/A
                Simulate Paper Color: N/A
            Advanced
                Print &as Bitmap: N/A
                Bitmap Resolution: N/A
                OPI Image Replacement: Off
                EPS: Off
                PDF: Off
                Bitmap Images: Off
                Transparency Flattener Preset: [High Resolution]
                Ignore Spread Overrides: Off
            • 3. Re: Print Blooket Problem. What I do?
              That is not an export. You creating postscript and distilling.
              I’ve given you the best advice. At the very least, try it.
              • 4. Re: Print Blooket Problem. What I do?
                I'm using the function "print blooket" into Indesign. I'm sorry, but I didn't understand your advice.
                I do like this because I need blooket type and creep to send the file to CPT and offset printer.
                • 5. Re: Print Blooket Problem. What I do?
                  Then you’ll have to live with the stitching.
                  • 6. Re: Print Blooket Problem. What I do?
                    Thanks for you help.
