I'm on a Mac using the latest Sierra. I can't get this shortcut to work. If I mouse to the Command, it works fine but it's a bit of travelling in Photoshop. I use Shortcuts a lot. It's interesting that it doesn't work in neither Elements nor Photoshop. Could it be a clash with the same command on my Mac?
Restart in Safe Mode? Are you kidding? I've re-assigned a shortcut which works and I'll use the menu selection in Elements. I won't be restarting the machine in the middle of work. Thanks anyway.
Have you added any Input Sources?
Apple>System Preferences>Keyboard>Input Sources
No, nothing added. I also checked all the system shortcuts and there was nothing remotely like that shortcut.
Thanks.
What is happening on using this (cmd+option+Shift+S) shortcut ?
Rupali
Nothing happens when I use the shortcut. But it will work when I mouse via the menu to that command (Save for Web). It's only the shortcut that doesn't work. Nothing actually happens.
