1 Reply Latest reply on Feb 23, 2017 1:47 PM by try67
    date time stamp when a user fills in field on a form
    ktpp
      Is there a way to capture the date in which a user fills in the first field on a adobe form?
        • 1. Re: date time stamp when a user fills in field on a form
          This is quite tricky to implement without having to embed a code that does it in all the fields in the file. The closest I got to it is by using this code as the custom calculation script of the field where you want this date to appear. You can set the field as read-only and then you'll have to reset the form in order to clear it.
          if (event.source && event.target.value=="") {
              event.value = util.printd("mm/dd/yyyy HH:MM", new Date());
