HELLLO Guys my name is Gilberto this is my first time using adobe products ,i used a different programs previously , i am experiencing some issues with Encore cs6
my video file MPEG is no showing etheir says pending or don't transcode i am not sure what this means , but i can hear the audio the weird thing is if i drag a short clip from my video files without been edited , it can be seen, i hope that aim being clear .please some one help
Welcome!
Encore is for authoring DVD and Blu-ray disks. While there are several workflows, you should import to Encore files that are DVD or BD legal and ready to go.
For DVD, export from Premiere Pro/Adobe Media Encoder as format MPEG2-DVD and the preset whatever you have (e.g. PAL SD widescreen progressive etc). You will import an .m2v and .wav files into Encore. In Encore project panel, under the DVD Transcode Status column you should see "Do Not Transcode" for the m2v file. The .wav file will show "Untranscoded" and with the defaults, Encore will transcode it to a3c.
Start with DVD, what do you see?
thanks for been there, well it seems that i have been doing as you say so, and it seems not working , after i drag or open my files M2v and wav files only the audio is working , the m2v file is either saying pending or not showing , you know there is a little icon right above it where you can preview audio and video , for the video it shows two arrows in counter clock shape . and if i drag it to my timeline it won't show.
in this case i drag this files as a timeline
Did you export from Premiere Pro or Adobe Media Encoder? Or something else?
Did you move the .m2v file from the directory where PR exported it or delete any files?
The pending suggests it is conforming, and that should not be necessary. And even if it is, it should not take long for such a short file.
Mr. Stan bear with me please, i believe i followed every single step , 1 i create a sequence according to the footage in P Pro, save it into a folder export it , to media encore then again save it to the same folder, and after being queued , i got both files M2v and wav audio. the file you saw in the screenshot the mpeg video don't show, but if i drag a file from my media without the same process, it opens, the video shows
If you import the m2v file back in PR, what do you see?
ok , so as you said or what i understood i tried to open my M2v and wave file in PP and it did not worked
something else ,Dynamic Link is disable in both PP and Encore and believe when i was trying or searching a way to active it this message show up
Dynamic link for Encore CS6 only works from PR CS6. It is not an option; this is not a problem, just can't do it.
Please post a screenshot of your export settings in Premiere Pro.
I don't see a problem there.
This is not your problem, but when exporting HD to SD, set the export crop (On the left side) to Scale to Fill. That removes the thin black lines on the left and right.
How big is the filesize of your m2v?
filesize is 84 MB
Ok i did try this several times before , i open a video file untouched from my folders and it works, i scroll over it and it runs ,but no audio and in the description line above the name video line the size is shown this is 3.9 GB and when i drag my project the video size file shows 0 bytes
Is 29.97 progressive a legal dvd format? i thought in had to be interlaced at 29.97 but I may well be wrong.
It is one of the presets. It's stored as interlaced, but progressive is allowed. Earlier players didn't always handle it.
Interlaced is allowed for DVD, but not for Blu-ray @29.97.
Progressive is only for certain resolution and or framerate: 29.97 not being one of them.
MIght want to look at this list:
I believe he is making a DVD.
In any event, no matter what the legality of the file, it should "appear" in Encore. Something is wrong somewhere!
did you receive my screenshots? because there is something that says Currently being moderated
give me a moment please
