I am trying to run OCR on two identical images having similar text content.
Acrobat is able to run the OCR but not able to recognize the characters properly. e.g. sometimes '(' and ')' are recognized as '/' and '\' resp.
While comparing these images after OCR, sometimes compare tool is creating small segments and compares it as image instead of comparing its text and displays "image replaced" message.
I want to take two identical images, run OCR and compare all the recognized text.
Any help is appreciated.
Thanks in advance.
Sorry for the issue you are facing. Can you please share the set of images where you are facing this issue.
You can use https://cloud.acrobat.com/send to share the file.
Thanks.
