10 Replies Latest reply on Jun 27, 2018 7:15 AM by Dirk Becker
    Mac files url to HFS path
    Loic.Aigon Adobe Community Professional
      Does anyone of you knows to convert this:
      "/Users/user/Desktop/myFile.ext"
      into
      "Macintosh HD:Users:user:Desktop:myFile.ext"
      Starting from a File myFile.ext located on the desktop ?
      I can do string concatenations and stuff or call applescript but I was looking at something more meaningful.
      TIA
      Loic
        • 1. Re: Mac files url to HFS path
          TᴀW Adobe Community Professional & MVP
          Hi Loic,
          How about:
          f = new File(Folder.desktop + "/myFile.ext");
          alert("Macintosh HD" + f.fsName.replace(/\//g, ":");
          Ariel
          • 2. Re: Mac files url to HFS path
            Well I guess I will go with this one
            Thx
            Loic
            • 3. Re: Mac files url to HFS path
              Hi Ariel,
              I would feel a little bit uneasy with this.
              On Mac OSX file names like shown in the screenshot below are also possible:
              ( "Schreibtisch" => "Desktop" )
              Placed as linked text files with InDesign on OSX showing in the Links panel:
              If I am using menu $ID/#LinksUICopyPlatformPath I get this with my text editor which is looking very promissing:
              Macname:Users:Username:Desktop:my/\File.txt
              Macname:Users:Username:Desktop:my\/File.txt
              And indeed, if I am looping the links and ask for filePath values I get exactly the results from above:
              var doc = app.documents[0];
              var links = doc.links.everyItem().getElements();
              for(var n=0;n<links.length;n++)
                  $.writeln(n+"\t"+links[n].filePath);
                  Result:
                  0    Macname:Users:Username:Desktop:my/\File.txt
                  1    Macname:Users:Username:Desktop:my\/File.txt
              I'm not so sure with your code.
              Hope I interpret it right. Correct me if I'm wrong.
              We have a File object do fsName on it and run a RegExp where a slash is replaced by a colon.
              And in front of the result string we add the name of the machine:
                  $.writeln(n+"\t"+"Macname"+File(links[n].filePath).fsName.replace(/\//g, ":"));
                  Result:
                  0    Macname:Users:Username:Desktop:my:\File.txt
                  1    Macname:Users:Username:Desktop:my\:File.txt
              The result is not looking good…
              Regards,
              Uwe
              • 4. Re: Mac files url to HFS path
                Hi Uwe,
                It is not best practice to use slashes in filenames on the Mac: OS X: Cross-platform filename best practices and conventions - Apple Support
                If Loic wishes to account for users who are using slashes nevertheless, I guess the thing to do would be to run the GREP on just the path part of the name and then add the file name. Something like this, I suppose (untested):
                alert("Macintosh HD" + f.parent.fsName.replace(/\//g, ":") + ":" + f.name);
                Ariel
                • 5. Re: Mac files url to HFS path
                  Hi guys,
                  No need to tear your heads off on this one. It's a very specific need. A scriptable plugin defines some function argument to be a HFS path. I was wondering if there was any predictable way of turning a file path into a HFS path like a non revealed method File.toHFS()
                  There will be one user (my client) so I can presume the context but It would have been nice to be agnostic.
                  Loic
                  • 6. Re: Mac files url to HFS path
                    Trevorׅ Adobe Community Professional
                    Hi All,
                    While I agree with Ariel that anyone who uses / or \ in a filename deserves at very least to have his system explode regardless of whether his using Mac, Android, Commodore 64  or Sinclair ZX8.
                    The above suggested solution however is not to great (even if it satisfies Loic).
                    My Mac has 2 internal hard drives, 2 external hard drives (Partition to into 6 partitions)  and about 6 server drives. Ok. that might be an overkill but that's how it is. Only one of them is called "Macintosh HD".
                    Anyways if one on InDesign then one can user this simple POSIX to HFS conversion.
                    It will even handle cases that don't deserve to be taken care of, (Maybe it will fail if the name contains a "  in it but that would not be tough to take care of)
                    var f, as;
                    f = Folder.desktop; // change as needed
                    as = 'POSIX file "' + f.fsName + '" as Unicode text';
                    alert(app.doScript(as, ScriptLanguage.APPLESCRIPT_LANGUAGE));
                    Hope that helps someone, regards,
                    Trevor
                    • 7. Re: Mac files url to HFS path
                      Hi Trevor,
                      Ariel's solution was fine for my really specific context. Yours extends the scope which is fine but this is typically what I wish I could avoid meaning relying on the context (like using applescript). I just think there isn't any universal and agnostic solution.
                      Thanks anyway
                      Loic
                      • 8. Re: Mac files url to HFS path
                        hi Trevor
                        Just to let you know that I will use this line of AS Code in my current project. So it was a great addition
                        • 9. Re: Mac files url to HFS path
                          Thanks for letting me know.
                          • 10. Re: Mac files url to HFS path
                            Dirk Becker Level 4
                            You can pass an array of arguments thru app.doScript, no need to convert the Folder to a literal.
                            Apparently this even works if you omit the UndoMode parameter.
                            Besides the file/folder argument is already passed as alias or similar, so we can omit the "POSIX file" coercion.
                            alert(app.doScript("item 1 of arguments as Unicode text", ScriptLanguage.APPLESCRIPT_LANGUAGE,[Folder.desktop]));
