Why I try to "send file" directly from Adobe it asks me to sign in multiple times and ends up not sending the pdf document via outlook. This use to be something I did all of the time. How can I remedy?
What product do you use? Reader or Acrobat, we have different forums for each product. The forum you posted in is not the best forum to help you with your issue. Mike
Temporarily moved from the PDF Workflow forum. If poster is using Acrobat Pro or Standard I will move to that forum.
Oops, I just moved it back to PDF workflow and can't move it back due to a technical problem.
Same here used to be effortless to sign and send until I paid Acrobat $$ to have yearly contracxt and has not worked since! Keep having to sign in and then can't send docs after signing, Shows up in the email but can't be opened to see if my signature is really there, can't save and open again says file not found! Worst yet is no way to get help but these stupid forums! Worst customer service ever!
