Hi there,
I have an Adobe Acrobat Pro DC document that has a form with drop down boxes. I would like to print the document with the content from the drop down menu showing.
I have already tried Print/Comments and Forms/Form Fields Only. It does not pull the content in the drop down boxes. Please help!
Not a fix but a workaround:
I had this problem when opening a filled out form that was saved on my pc and printing it. The workaround is to open every drop-down menu and reselect everything again. Tedious but hopefully this helps until Adobe fixes it.
This can happen when the file is opened in a non-compliant PDF viewer, such as Apple Preview.
Try exporting the data to an FDF or text file, and then import it back it.
