Hi Colleagues!
Need to complete the script (test) which count how many times WORD appeared in PDF document.
I am using this script
Option Explicit
Dim accapp, acavdocu
Dim pdf_path, bReset, Wrd_count
pdf_path = "C:\Tips.pdf"
Set accapp = CreateObject( "AcroExch.App" )
accapp.Show()
Set acavdocu = CreateObject( "AcroExch.AVDoc" )
If acavdocu.Open( pdf_path, "" ) Then
acavdocu.BringToFront()
bReset = 1 : Wrd_count = 0
'FindText:Finds the specified text, scrolls so that it is visible, and highlights it
Do While acavdocu.FindText( "Primary", 1, 1, bReset )
bReset = 0 : Wrd_count = Wrd_count + 1
Wait 0, 200
Loop
End If
the problem is that loop didn't finish. It count words on each page till the end (8 pages) and then started again,
Please tel me how can I count all word which I need and exit from the loop.
Thank you in advance
FindText isn't designed for word counting, and it may well loop. It's just a shortcut to showing text in the UI. You probably need to extract all words, check each one and count matched. One way is the JavaScript document.getPageNthWord method.
You can store the current page with something like:
Set gAVPageView = acavdocu.GetAVPageView
Set gPdPage = gAVPageView.GetPage
pgn = gPDPage.GetNumber
Save pgn as last page and if the current page (pgn) is smaller as the last page quit the loop or use this in combination with
PDDoc.GetNumPages().
br. Reinhard
Mmmh, I just remembered an old vbs study to find text in a pdf. Perhaps you can use that.
'//Settings: Filename and Word to find
FileNM = "d:\Test2.pdf"
WordTF = "Hello World"
'// Check if file exist
set fs = CreateObject("Scripting.FileSystemObject")
if not fs.FileExists(FileNM) then
MsgBox "Ups! " & FileNM & " doesn't exist? " & "Try new!", vbExclamation
WScript.quit
end if
'//Start Acrobat and Open the File into View
Set gApp = CreateObject("AcroExch.App")
Set gAVDoc = CreateObject("AcroExch.AVDoc")
OK = gAVDoc.Open(FileNM, "")
if not OK Then if MsgBox("Error open Basic File") then Wscript.quit
'//comment both out to work hidden
gApp.show
gAVDoc.bringToFront()
'// let's go
readAndFindText() '// 15 sec for 100 pages (10 sec hidden in mode)
function readAndFindText()
set gPdDoc = gAVDoc.GetPdDoc()
maxPages = gPdDoc.GetNumPages
foundOnPage = ""
Set gAVPageView = gAVDoc.GetAVPageView
for x = 0 to maxPages -1 '// loop over all the pages
gAVPageView.goto(x)
Set PdfPage = gAVPageView.GetPage
Set PageHL = CreateObject("AcroExch.HiliteList")
PageHL.Add 0,9000 '<<--SET in FILE! (Start,END[9000=All])
Set PageSel = PdfPage.CreatePageHilite(PageHL)
for i = 0 to PageSel.Getnumtext - 1 '//loop to get all Words on current Page
pdfData = PDFData & PageSel.GetText(i)
Next
msgbox(pdfData)
if instr(pdfData, WordTF) then foundOnPage = foundOnPage &x + 1 &","
'msgBox("page: " &x &" / " &foundOnPage &vbLF &pdfDATA)
pdfData = ""
next
msgbox("found on Page: " &foundOnPage)
end function
Set gPdPage = nothing
Set gAVPageView = Nothing
Set gAVDOC = Nothing
Set gAPP = Nothing
