1 Reply Latest reply on Feb 25, 2017 7:58 AM by Laubender
    Table Column width
    Sen.Soft Level 1
      Need an Indesign java script to know the table column width value.
      Example
      Col 110p8.75128.75129
      Col 24p4.852.853
      Col 33p84444
      Col 41p1.2513.2513
      Col 54p10.458.458
        • 1. Re: Table Column width
          with ExtendScript scripting you could get the values with:
          // Select a table, not a text frame
          alert(app.selection[0].columns.everyItem().width);
          Or if you want to write the values to the JavaScript Console of the ExtendScript Toolkit (ESTK):
          $.writeln(app.selection[0].columns.everyItem().width);
          The values are expressed in the Ruler Units of your document.
          E.g. If the ruler is the set to Points, then the values are in points.
          If you want a tool to store and reapply column width values see
          Gerald Singelmann:
          Set table-columns numerically II | InDesign FAQ
          Gerald's script is downloadable from his blog and you can inspect the code.
          Regards,
          Uwe
